IC Python API:RLPy RUi
Contents
- 1 Description
- 2 Member Functions
- 2.1 GetMainWindow ( self )
- 2.2 AddMenu ( self, strMenuName, eParent )
- 2.3 RemoveMenu ( self, pMenu )
- 2.4 AddHotKey ( self, strKeySequence )
- 2.5 RemoveHotKey ( self, pAction )
- 2.6 GetResolutionType ( self )
- 2.7 GetCSSType ( self )
- 2.8 ShowMessage ( self, strTitle, strMsg, eBtn, bChecked, strCheckBoxMsg )
- 2.9 OpenFileDialog ( self, strFilter, strStartingDirectory )
- 2.10 OpenFilesDialog ( self, strFilter, strStartingDirectory )
- 2.11 SaveFileDialog ( self, strFilter )
- 2.12 CreateRDialog ( self, eDialogType )
- 2.13 CreateRDockWidget ( self )
- 2.14 Returns
- Main article: Modules.
- Last modified: 05/12/2020
Description
This class is a package of instructions related to the application user interface (UI). It includes the ability to bridge communication between plugins and the application UI system, provides operations for the main window and menu, application version settings, show message boxes, open file browse dialog, as well as adding RIDialog and RIDockWidget related components, and much more. By using this class, developers can define plugin behaviors via custom user interfaces to achieve their goals.
Member Functions
Get the QWidget address for the main window. You can bind the main window to a PySide object by using this function, for UI operations.
Returns
- QWidget address for the main window - QWidget address
1 # Get MainWindow QWidget address
2 main_widget = wrapInstance(int(RLPy.RUi.GetMainWindow()), PySide2.QtWidgets.QWidget)
Currently, this function can only create menu items within the Plugins menu. The Qmenu address is returned upon creation.
Parameters
- strMenuName [IN] The desired menu item name - string
- eParent [IN] The parent menu for this menu item - RLPy.EMenu
Returns
- The QMenu address for the newly created menu item - QMenu address
1 # Add menu item to Plugins menu
2 menu_item = "TestMenu"
3 menu_address = RLPy.RUi.AddMenu(menu_item, RLPy.EMenu_Plugins)
4 print(menu_address)
5
6 # add Test menu
7 plugin_menu = wrapInstance(int(RLPy.RUi.AddMenu("Test", RLPy.EMenu_Plugins)), PySide2.QtWidgets.QMenu)
8 plugin_action = plugin_menu.addAction("sub menu action")
9 plugin_action.triggered.connect(do_somthing)
Remove a menu item from the main window. Currently, this function only supports removal of menu items from the Plugins menu.
Parameters
- pMenu [IN] Menu item address for removal - QMenu address
Return
- Success - RLPy.RStatus.Success
- Failure - RLPy.RStatus.Failure
1 # Remove menu item from Plugins menu
4 result = RLPy.RUi.RemoveMenu(menu_address)
5 print(result)
Create and register a hotkey event. The input hotkey string will be compared with the keys within QKeySequence of the Qt component and returns a QAction address. If the given hotkey is already registered to another event, then the previous event will be replaced by the newly registered hotkey event. In order to revert to the previous event, one must first unregister the current event.
Parameters
- strKeySequence [IN] The desired hot key name, to be compared to the keys in the QKeySequence of the Qt component - string
Returns
The QAction address for the newly created hotkey - QAction address
1 import PySide2
2 from PySide2.QtWidgets import QWidget
3 from PySide2.shiboken2 import wrapInstance
4
5 # Define global function
6 def do_space_action():
7 print("Space action start.")
8
9 # Add hot key to trigger action
10 space_action = wrapInstance(int(RLPy.RUi.AddHotKey("Space")), PySide2.QtWidgets.QAction)
11 space_action.triggered.connect(do_space_action)
12
13 # Add hot key(combo key) to trigger action
14 space_action = wrapInstance(int(RLPy.RUi.AddHotKey("Ctrl+G")), PySide2.QtWidgets.QAction)
15 space_action.triggered.connect(do_space_action)
Remove a hotkey event registered to the given QAction address.
Parameters
- pAction [IN] The QAction address of the hotkey designated for removal - QAction address
Return
1 import PySide2
4 # Define global function
5 def do_space_action():
6 print("Space action start.")
7
8 # Remove hotkey
9 space_action = wrapInstance(int(RLPy.RUi.AddHotKey("Space")), PySide2.QtWidgets.QAction)
10 space_action.triggered.connect(do_space_action)
11 result = RLPy.RUi.RemoveHotKey(space_action)
12 print(result)
Get the application resolution settings.
Returns
- The current application resolution mode - RLPy.EResolutionType
1 # Get resolution type
2 resolusion_type = RLPy.RUi.GetResolutionType()
3 print(resolusion_type)
GetCSSType ( self )
Get the current application cascading style sheet (CSS) settings.
Returns
- Application CSS settings - RLPy.ECSSType
1 # Get CSS type
2 css_type = RLPy.RUi.GetCSSType()
3 print(css_type)
Display a message box on the screen. The title, text content, and button options are configurable. Bitwise operations can be applied to combine different button types. The message box can also be set to contain a checkbox and a message to go with it. Developers can configure the appropriate response for the RLPy.EMsgButton enum return value. Activated checkboxes in the message box can be intercepted with the RLPy.EMsgButton_Ok return value.
See Also: RLPy.EMsgButton
Parameters
- strTitle [IN] MessageBox title name - string
- strMsg [IN] MessageBox message - string
- eBtn [IN] MessageBox button options (Use bitwise operators to combine different types of buttons) - RLPy.EMsgButton
- bChecked [IN] Whether to show a checkbox. Once it is present, its check state is also determined by this parameter - boolean
- strCheckBoxMsg [IN] The message accompanies the checkbox - string
Returns
- The integer value of this user interface's RLPy.EMsgButton - integer
1 # show message box
2 RLPy.RUi.ShowMessageBox("Title", "Msg", RLPy.EMsgButton_Ok)
3
4 # show message box with checked option
5 RLPy.RUi.ShowMessageBox("Title", "Msg", RLPy.EMsgButton_Ok, True, "CheckBoxMsg")
6
7 # Show normal message box
8 button_result_1 = RLPy.RUi.ShowMessageBox("Test Message Box", "Show message box test.", RLPy.EMsgButton_Ok)
9 if button_result_1 == RLPy.EMsgButton_Ok:
10 print("Click button Ok.")
11
12 # Show one-checked message box
13 button_result_2 = RLPy.RUi.ShowMessageBox("Test Message Box", "Show message box test one-checked.", RLPy.EMsgButton_Ok, True, "Don’t show next time.")
14 if btn_result != RLPy.EMsgButton_OkDontAskAgain: //must OK??
15 print("Click Button Ok.")
16 else:
17 print("Click Button Don’t ask again.")
Browse for a file by opening the file open dialog window according to the extension filter and a starting directory. If the starting directory is an empty string, then it will automatically browse to the last directory location recorded by the application as the opening path.
See also: OpenFilesDialog
Parameters
- strFilter [IN] File extension filters - string
- strStartingDirectory [IN] The starting directory when opening a file (can be left blank) - string
Returns
- The directory path of the opened file - string
1 # Open file dialog without starting directory
2 file_path = RLPy.RUi.OpenFileDialog("Json Files(*.json)")
3 print(file_path)
4
5 # open multiple files dialog
6 file_path_list = RLPy.RUi.OpenFilesDialog("Json Files(*.json)")
7 print(file_path_list)
8
9 # Open file dialog with starting directory
10 template_data_path = RLPy.RApplication.GetTemplateDataPath()
11 file_path = RLPy.RUi.OpenFileDialog("Json Files(*.json)", template_data_path)
12 print(file_path)
Browse for multiple files by opening the file open dialog window according to the extension filter and a starting directory. If the starting directory is an empty string, then it will automatically browse to the last directory location recorded by the application as the opening path.
See also: OpenFileDialog
Parameters
Returns
- A list of absolute paths to multiple files - string list
1 # Open file dialog with all files
2 file_path = RLPy.RUi.OpenFileDialog("All Files(*)")
3 print(file_path)
4
5 # Open file dialog with one format
6 file_path = RLPy.RUi.OpenFileDialog("Json Files(*.json)")
7 print(file_path)
8
9 # Open file dialog with multi format
10 file_path = RLPy.RUi.OpenFileDialog("Image Files(*.jpg; *.jpeg; *.bmp; *.gif; *.png; *.tga)")
11 print(file_path)
12
13 # Open file dialog with starting directory
14 template_data_path = RLPy.RApplication.GetTemplateDataPath()
15 file_path = RLPy.RUi.OpenFileDialog("Json Files(*.json)", template_data_path)
16 print(file_path)
Launch a save file dialog window and save a file to a specified file path. The possible file types can be restricted by the strFilter parameter. Once a file is saved, its absolute path is returned.
Parameters
Returns
- File path of the saved file - string
1 # save file dialog
2 file_path = RLPy.RUi.SaveFileDialog("Json Files(*.json)")
3 print(file_path)
Create either a normal or exclusive dialog object and return it. A normal dialog can exist among other instances at the same time, while exclusive means that only one instance can be displayed at any given time.
Parameters
- eDialogType [IN] type of dialog, if nothing is entered, then a normal dialog is created - RLPy.EDialogType
Returns
- Smart pointer to the newly created dialog object - RIDialog smart pointer
1 # Create normal RIDialog instance
2 rl_normal_dialog = RLPy.RUi.CreateRDialog()
3 print(rl_normal_dialog)
4
5 # Create normal RIDialog instance
6 rl_normal_dialog = RLPy.RUi.CreateRDialog(RLPy.EDialogType_Normal)
7 print(rl_normal_dialog)
8
9 # Create exclusive RIDialog instance
10 rl_exclusive_dialog = RLPy.RUi.CreateRDialog(RLPy.EDialogType_Exclusive)
11 print(rl_exclusive_dialog)
Create a new dock widget object and return it as RIDockWidget.
Parameters
- eParent [IN] The parent menu for this menu item, currently only supports the plugins menu - RLPy.EMenu
Returns
- The newly created dock widget - RIDockWidget
1 # Create RIDockWidget instance
2 rl_dockwidget = RLPy.RUi.CreateRDockWidget()
3 print(rl_dockwidget)
