IC Python API:RLPy RVector4
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/13/2020
Description
This class represent a 4D vector (x, y, z, w). This class provides access to RLPy's internal 4D vector math library allowing 4D vectors to be handled easily, and in a manner compatible with internal RLPy data structures. It also supports operators and provides some convenient constants:
Constant Description
RVector4.ZERO 4D zero vector: (0, 0, 0, 0)
RVector4.UNIT_X 4D x unit vector: (1, 0, 0, 0)
RVector4.UNIT_Y 4D y unit vector: (0, 1, 0, 0)
RVector4.UNIT_Z 4D z unit vector: (0, 0, 1, 0)
RVector4.UNIT_W 4D w unit vector: (0, 0, 0, 1)
RVector4.UNIT_XYZW 4D vector: (1, 1, 1, 1)
Constructor & Destructor
__init__ ( )
Initialize a new 4D vector object that is zeroed out: (0, 0, 0, 0).
1 a = RLPy.RVector4()
__init__ ( a, b, c, d )
Initialize a new 4D vector object as a 4D vector: (x, y, z, w).
Parameters
a [IN] A numerical value for x coordinate - float or int
b [IN] A numerical value for y coordinate - float or int
c [IN] A numerical value for z coordinate - float or int
d [IN] A numerical value for w coordinate - float or int
1 a = RLPy.RVector4(1, 2, 3, 4)
__init__ ( *args )
Initialize a new 4D vector object with another 4D vector object: args. This new 4D vector object has the same value as *args.
Parameters
args [IN] a 4D vector object - RVector4
2 b = RLPy.RVector4(a)
Operators
The "equal to" operator.
2 b = a
3
4 print(a == b) #True
The "not equal to" operator.
See Also: ==
2 b = RLPy.RVector4(1, 2, 3, 4)
3
4 print(a != b) # True
The "less than" operator. Similar to string comparison: Returns True upon the first match that is less than, and False if it is greater than. If the current comparison is equal, continue onto the next element. If all elements are equal then return False.
See Also: <=
 1 a = RLPy.RVector4(0, 1, 5, 2)
 2 b = RLPy.RVector4(0, 1, 5, 3)
 3 c = RLPy.RVector4(1, 0, 1, 0)
 4 d = RLPy.RVector4(0, 1, 5, 2)
 5
 6 print(a < b)        # True
 7 print(b < c)        # True
 8     print('b < c')
 9 if a < d:           # False
10     print('a < d')
The "greater than" operator. Similar to string comparison: Returns True upon the first match that is greater than, and False if it is less than. If the current comparison is equal, continue onto the next element. If all elements are equal then return False.
See Also: >=
 5
 6 if b >a:        # True
 7 print('b >a')
 8 if c >b:        # True
 9 print('c >b')
10 if a >d:        # True
11 print('a >d')
The "less than or equal" operator. Similar to string comparison: Returns True upon the first match that is less than, and False if it is greater than. If the current comparison is equal, continue onto the next element. If all elements are equal then return True.
See Also: <
 5
 6 if a<= b:       # True
 7 print('a<= b')
 8 if b<= c:       # True
 9 print('b<= c')
10 if a<= d:       # True
11 print('a<= d')
The "greater than or equal" operator. Similar to string comparison: Returns True upon the first match that is greater than, and False if it is less than. If the current comparison is equal, continue onto the next element. If all elements are equal then return True.
See Also: >
 5
 6 if b >= a:      # True
 7 print('b >= a')
 8 if c >= b:      # True
 9 print('c >= b')
10 if a >= d:      # False
11 print('a >= d')
The "addition" operator. Perform a 4D vector addition.
See Also: +=
1 a = RLPy.RVector4(0, 1, 2, 3)
3 c = a + b
4
5 print(str(c.x) + ', ' + str(c.y) + ', ' + str(c.z) + ', ' + str(c.w)) # 1.0, 3.0, 5.0, 7.0
The "subtraction" operator. Perform a 4D vector subtraction.
See Also: -=
2 b = RLPy.RVector4(3, 2, 1, 0)
3 c = b - a
4
5 print(str(c.x) + ', ' + str(c.y) + ', ' + str(c.z) + ', ' + str(c.w)) # 3.0, 1.0, -1.0, -3.0
The "multiplication" operator. Perform a scalar multiplication when the second operand is an integer or float. If the second operand is another 4D vector, then the corresponding elements are multiplied.
See Also: *=
2 b = a * 2
3 c = a * a
4
5 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z) + ', ' + str(b.w)) # 2.0, 4.0, 6.0, 8.0
6 print(str(c.x) + ', ' + str(c.y) + ', ' + str(c.z) + ', ' + str(c.w)) # 1.0, 4.0, 9.0, 16.0
The "division" operator. Perform a scalar division when the second operand is an integer or float. If the second operand is another 4D vector, then the corresponding elements are divided.
See Also: /=
2 b = a / 2
3 c = RLPy.RVector4(2, 2, 10, 2)
4 d = a / c
5
6 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z) + ', ' + str(b.w)) # 0.5, 1.0, 1.5, 2.0
7 print(str(d.x) + ', ' + str(d.y) + ', ' + str(d.z) + ', ' + str(d.w)) # 0.5, 1.0, 0.3, 2.0
The "unary minus" operator. Inverse the sign of each element.
See Also: -=
2 b = -a
3
4 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z) + ', ' + str(b.w)) # -1.0, -2.0, -3.0, -4.0
The "addition assignment" operator.
See Also: +
3 a += b
4
5 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 1.0, 3.0, 5.0, 7.0
The "subtraction assignment" operator.
See Also: -
1 a = RLPy.RVector4(0, 1, 4, 5)
2 b = RLPy.RVector4(1, 2, 3, 1)
3 a -= b
4
5 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # -1.0, -1.0, 1.0, 4.0
The "multiplication assignment" operator.
See Also: *
2 a *= 2
3 b = RLPy.RVector4(1, 2, 3, 4)
4 c = RLPy.RVector4(2, 3, 4, 5)
5 b *= c
6
7 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 2.0, 4.0, 6.0, 8.0
8 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z) + ', ' + str(b.w)) # 2.0, 6.0, 12.0, 20.0
The "division assignment" operator.
See Also: /
2 a /= 2
4 c = RLPy.RVector4(2, 4, 2, 2)
5 b /= c
6
7 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 0.5, 1.0, 1.5, 2.0
8 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z) + ', ' + str(b.w)) # 0.5, 0.5, 1.5, 2.0
Member Functions
Dot (self, vV)
Calculate dot product with the given vector.
3
4 print(a.Dot(b)) #30.0
Parameters
vV [IN] The vector to compute dot product - RVector4
Returns
Returns the value of the dot product - float
Inverse (self)
Invert every element of this 4D vector.
1 a = RLPy.RVector4(0.5, 2, 4, 1)
2 b = a.Inverse()
3
4 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z) + ', ' + str(b.w)) # 2.0, 0.5, 0.25, 1.0
Returns
Returns the inversed vector - RVector4
Length (self)
Get the length (magnitude) of this 4D vector.
Returns
4D vector magnitude - float
1 a = RLPy.RVector4(1, 1, 1, 1)
3 print(a.Length()) # 2.0
Normalize (self)
Normalize this 4D vector.
Returns
Length of this 4D vector before normalization - float
SetW
Set the value of the w-axis.
3 print(a.Normalize())    # 2.0
4 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 0.5, 0.5, 0.5, 0.5
Parameters
tW [IN] the value of the w-axis - float
2 a.SetW(10)
3
4 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 1.0, 1.0, 1.0, 10.0
SetX (self, tX)
Set the value of the x-axis.
Parameters
tX [IN] the value of the x-axis - float
2 a.SetX(10)
3
4 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 10.0, 1.0, 1.0, 1.0
SetY (self, tY)
Set the value of the y-axis.
Parameters
tY [IN] the value of the y-axis - float
2 a.SetY(10)
3
4 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 1.0, 10.0, 1.0, 1.0
SetZ (self, tZ)
Set the value of the z-axis.
Parameters
tZ [IN] the value of the z-axis - float
2 a.SetZ(10)
3
4 print(str(a.x) + ', ' + str(a.y) + ', ' + str(a.z) + ', ' + str(a.w)) # 1.0, 1.0, 10.0, 1.0
SquaredLength (self)
Squared length of this 4D vector.
Returns
Returns the squared length of this 4D vector - float
3 print(a.SquaredLength()) # 4.0
XY (self)
Get the first 2 elements of this 4D vector (X, Y) as a 2D vector.
Returns
Returns a 2D vector - RVector2
2 b = a.XY()
3
4 print(str(b.x) + ', ' + str(b.y)) # 1.0, 2.0
XYZ (self)
Get the first 3 elements of this 4D vector (X, Y, Z) as a 3D vector.
Returns
Returns a 3D vector - RVector3
2 b = a.XYZ()
3
4 print(str(b.x) + ', ' + str(b.y) + ', ' + str(b.z)) # 1.0, 2.0, 3.0
