IC Python API:RLPy RISpotLight
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 06/22/2020
Description
This class provides spotlight related operations, i.e. whether or not to cast shadows, light color, light ray direction, light strength, etc.
Inheritance
RIBase > RIObject > RILight > RISpotLight
Examples
 1 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Spotlight") # Find the spotlight by name
 3 # set Parent
 4 prop2 = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box2")
 5 result = light_object.SetParent(prop2)
 6 result = light_object.SetParent(None) #detach from parent
 7
 8 # link to &  unlink
 9 result = light_object.LinkTo(prop2, RLPy.RTime(0))
10 result = light_object.UnLink(RLPy.RTime(0))
11 # set name
12 light_object.SetName( "new_name" )
13 #get bound
14 ret_max = RLPy.RVector3()
15 ret_center = RLPy.RVector3()
16 ret_min = RLPy.RVector3()
17 ret = light_object.GetBounds( ret_max, ret_center, ret_min )
18 print(ret)
19 #get pivot
20 ret_pos = RLPy.RVector3()
21 ret_rot = RLPy.RVector3()
22 light_object.GetPivot( ret_pos, ret_rot )
23 print(ret)
24 #clone object
25 clone_light_object = light_object.Clone()
26 print( clone_light_object )
27 #is selected
28 RLPy.RScene.SelectObject(light_object)
29 print(light_object.IsSelected()) #True
Member Functions
GetDarkenShadowStrength ( self )
Get the Spotlight's shadow strength at a given point in time (0 to 100).
See Also: SetDarkenShadowStrength
Returns
Spotlight's shadow strength - float
3 #get light shadow strength
4 print(light_object.GetDarkenShadowStrength())
GetRange ( self )
Get the Spotlight's range distance.
See Also: SetRange
Returns
Spotlight's range attribute - float
3 #get light range
4 print(light_object.GetRange())
GetSpotLightBeam( self, nAngle, nFalloff, nAttenuation )
Get the Spotlight's light beam attributes, e.g. beam angle and spill light attenuation (falloff intensity).
⚠ Current implementation is faulty, subject to change in later editions.
See Also: SetSpotLightBeam
Parameters
nAngle [OUT] Spotlight's angle value - int
nFalloff [OUT] Spotlight's falloff value - int
nAttenuation [OUT] Spotlight's attenuation value - int
Returns
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
 3 # Set light beam
 4 light_object.SetSpotLightBeam(RLPy.RTime(0), 90, 50, 2)
 5
 6 # Get light beam
 7 angle = 0
 8 falloff = 0
 9 attenuation = 0
10 status, angle, falloff, attenuation = light_object.GetSpotLightBeam(angle, falloff, attenuation)
11
12 print(status.IsError())  # False
13 print(angle)  # 90
14 print(falloff)  # 50
15 print(attenuation)  # 2
IsCastShadow ( self )
Check whether or not the Spotlight is casting shadows.
See Also: SetCastShadow
Returns
True if the spotlight is casting shadows, else False - bool
3 print(light_object.IsCastShadow())
SetCastShadow ( self, bEnable )
Turn on / off the Spotlight's cast shadows.
See Also: IsCastShadow
Parameters
bEnable [IN] Whether to cast shadows - bool
Returns
2 light_object.SetCastShadow(True)
SetDarkenShadowStrength ( self, kTime, fStrength )
Set the Spotlight's shadow strength at a given point in time (0 to 100).
See Also: GetDarkenShadowStrength
Parameters
fStrength [IN] Spotlight shadow strength value - float
Returns
3 # Set light shadow strength
4 light_object.SetDarkenShadowStrength(RLPy.RTime(0), 50.0)
SetRange ( self, kTime, fRange )
Set the Spotlight's range value at a given point in time.
See Also: GetRange
Parameters
kTime [IN] Time at which to set the beam - RTime
fRange [IN] Spotlight range value - float
Returns
3 # Set light range
4 light_object.SetRange(RLPy.RTime(0), 1000.0)
5 print(light_object.GetRange())
SetSpotLightBeam ( self, kTime, fAngle, fFalloff, fAttenuation )
Set the Spotlight's light beam attributes at a given point in time. These attributes include the light beam's angle and spill light attenuation (falloff intensity).
See Also: GetSpotLightBeam
Parameters
fAngle [IN] Light angle value - float
fFalloffPower [IN] Light falloff power value - float
fAttenuation [IN] Light attenuation - float
Returns
1 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Spotlight")  # use light name to find object
3 # set light beam
4 angle = 135.0
5 falloff_power = 40.0
6 attenuation = 2
7 light_object.SetSpotLightBeam(RLPy.RTime(0), angle, falloff_power, attenuation)
