IC Python API:RLPy RGlobal
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules.
Detailed Description
This class providing common API global functions.
# Get Secen info
print(RLPy.RGlobal.GetProjectLength()) # print project length of the current scene
print(RLPy.RGlobal.GetFps()) # print 60 FPS
# Time info
RLPy.RGlobal.SetTime(RLPy.RTime(30000)) # set time to 30s
print(RLPy.RGlobal.GetTime().GetValue()) # print 30000
print(RLPy.RGlobal.GetStartTime().GetValue()) # print start time
print(RLPy.RGlobal.GetEndTime().GetValue()) # print end time
# play control
RLPy.RGlobal.Play(RLPy.RTime(0), RLPy.RTime(1000)) # play form 0 to 1s
RLPy.RGlobal.Stop() # stop
RLPy.RGlobal.Pause() # pause
# Get Environment info
temp = ""
ret_list = RLPy.RGlobal.GetPath(RLPy.EPathType_Temp, temp) # print path,like: Temp,TemplateContent,CustomContent......
print(ret_list[1])
# undo / redo
RLPy.RGlobal.BeginAction("Motion")
# do something
RLPy.RGlobal.EndAction()
Member Functions
BeginAction
RLPy.RGlobal.BeginAction ( strAction )
Begin action.
Parameters
strAction [IN] action name - string
DoPluginTrialFollowUp
RLPy.RGlobal.DoPluginTrialFollowUp ( strProductNamePath )
Trial Follow up (Internal use)
Parameters
strProductNamePath [IN] Product name path - string
DoSNVerification
RLPy.RGlobal.DoSNVerification ( nProductID, strRegistry, strProductName, strSNFailTitle, strSNFailMsg, strSNExceedTitle, strSNExceedMsg )
Verify serial number.
Parameters
nProductID [IN] product ID - int
strRegistry [IN] registry - string
strProductName [IN] product name - string
strSNFailTitle [IN] fail title - string
strSNFailMsg [IN] fail message - string
strSNExceedTitle [IN] exceed title - string
strSNExceedMsg [IN] exceed message - string
Returns
Remain days of trial version - bool
EndAction
RLPy.RGlobal.EndAction ( )
End action.
GetEndTime
RLPy.RGlobal.GetEndTime ( )
Get end frame time.
Returns
End frame time - RLPy.RTime
import RLPy
time = RLPy.RGlobal.GetEndTime() # Grab the end time in milliseconds.
# Get seconds from milliseconds.
mark_out_secs = round(time.GetValue() * 0.001)
print("Timeline mark-out located at {0} seconds.".format(mark_out_secs))
# Timeline mark-out located at 30 seconds.
mark_out_frame = RLPy.RTime.GetFrameIndex(time, RLPy.RGlobal.GetFps())
print("Timeline mark-out on frame {0}.".format(mark_out_frame))
# Timeline mark-out on frame 1799.
GetFps
RLPy.RGlobal.GetFps ( )
Get frame per second.
Returns
Frame rate - int
import RLPy
# Get the project frames per second.
print(RLPy.RGlobal.GetFps()) # Get frames per second
# 60
GetMocapManager
RLPy.RGlobal.GetMocapManager ( )
Get mocap manager.
Returns
Pointer to mocap manager - RLPy.RIMocapManager
GetPath
RLPy.RGlobal.GetPath ( ePath, strPath )
Get path.
Parameters
ePath [IN] path type - RLPy.EPathType
  • RLPy.EPathType_Temp Temporary folder.
  • RLPy.EPathType_TemplateContent Template content folder.
  • RLPy.EPathType_CustomContent Custom content folder.
  • RLPy.EPathType_ProgramDefault Program default folder.
  • RLPy.EPathType_Morph Morph data folder.
  • RLPy.EPathType_CreateFace CreateFace data folder.
  • RLPy.EPathType_Puppet Puppet data folder.
  • RLPy.EPathType_FacialLayer Facial layer data folder.
  • RLPy.EPathType_ShareTemplateContent Shared template content folder.
  • RLPy.EPathType_Thumb Thumbnail folder.
  • RLPy.EPathType_Image Image folder.
  • RLPy.EPathType_CreatorAssets Creator assets folder.
  • RLPy.EPathType_Resource Resource folder.
  • RLPy.EPathType_FacialSystem Facial system folder.
  • RLPy.EPathType_CustomWidget Custom widget folder.
  • RLPy.EPathType_iCloneAssets iClone assets folder
strPath [OUT] path name - string
Return Values
RLPy.RStatus.Success Success
RLPy.RStatus.Failure Fail
import RLPy
# Print out a few path locations (Individual path locations may vary).
temp = ""
print("Temp folder: "+ret_list[1])
# Temp folder: C:\Users\User_Name\AppData\Local\Temp\iClone7Temp\iClone7Temp\
ret_list = RLPy.RGlobal.GetPath(RLPy.EPathType_TemplateContent, temp)
print("Template content folder: "+ret_list[1])
# Template content folder: C:\Users\Public\Documents\Reallusion\Template\iClone 7 Template
ret_list = RLPy.RGlobal.GetPath(RLPy.EPathType_CustomContent, temp)
print("Custom content folder: "+ret_list[1])
# Custom content folder: C:\Users\Public\Documents\Reallusion\Custom\iClone 7 Custom
ret_list = RLPy.RGlobal.GetPath(RLPy.EPathType_ProgramDefault, temp)
print("Program default folder: "+ret_list[1])
# Program default folder: C:\Program Files\Reallusion\iClone 7\Program\Default\
GetProjectLength
RLPy.RGlobal.GetProjectLength ( )
Get project length.
Returns
Project length - RLPy.RTime
import RLPy
# Grab the project duration in milliseconds
time = RLPy.RGlobal.GetProjectLength()
project_secs = round(time.GetValue() * 0.001)
print("This project length is {0} seconds.".format(project_secs))
# This project length is 30 seconds.
project_frames = RLPy.RTime.GetFrameIndex(time, RLPy.RGlobal.GetFps())
print("This project has {0} frames.".format(project_frames))
# This project has 1800 frames.
GetStartTime
RLPy.RGlobal.GetStartTime ( )
Get start frame time.
Returns
Start frame time - RLPy.RTime
import RLPy
time = RLPy.RGlobal.GetStartTime() # Grab the start time in milliseconds.
print("Timeline starts at {0} milliseconds.".format(time.GetValue()))
# Timeline starts at 0.0 milliseconds.
GetTime
RLPy.RGlobal.GetTime ( )
Get current frame time.
Returns
Current time - RLPy.RTime
import RLPy
time = RLPy.RGlobal.GetTime() # Get the current frame time.
print(time.GetValue()) # Return the current frame time in milliseconds.
IsPlaying
RLPy.RGlobal.IsPlaying ( )
Is application playing?
Returns
True when application playing - bool
import RLPy
# Check if the timeline playback is active.
print(RLPy.RGlobal.IsPlaying())
# True / False
Pause
RLPy.RGlobal.Pause ( )
Pause the project.
Play
RLPy.RGlobal.Play ( kStart, kEnd )
Play the project.
Parameters
kStart [IN] start time - RLPy.RTime
kEnd [IN] end time - RLPy.RTime
import RLPy
RLPy.RGlobal.Play(RLPy.RTime(0), RLPy.RTime(1000)) # play from 0 to 1 second
RemoveAllAnimations
RLPy.RGlobal.RemoveAllAnimations ( spObject )
Remove all animations of object. ( Experimental API )
Parameters
spObject [IN] The object to remove animations - RLPy.RIObject
Return Values
RLPy.RStatus.Failure Remove failed
RenderVideo
RLPy.RGlobal.RenderVideo ( )
Export project into video file. ( Experimental API )
Return Values
SetTime
RLPy.RGlobal.SetTime ( kTime )
Set current frame time.
Parameters
kTime [IN] Specifies the time to set - RLPy.RTime
Return Values
import RLPy
frame = 50
# convert frame number to RTime.
time = RLPy.RTime.IndexedFrameTime(frame, RLPy.RGlobal.GetFps())
RLPy.RGlobal.SetTime(time) # Move the playhead to the indexed frame time.
Stop
RLPy.RGlobal.Stop ( )
Stop playing.
TrialVersionRemainingDays
RLPy.RGlobal.TrialVersionRemainingDays ( strBinPath, uProductID, strProductFold, strRegRoot )
Get remain days of trial version.
Parameters
strBinPath [IN] bin file path - string
kProductID [IN] product ID
kProductFold [IN] product Folder
kRegRoot [IN] registry root
Returns
Remain days of trial version - int
