IC Python API:RLPy RColor
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules.
Detailed Description
This class represent the color data RGBA.
Operators
This class supports the following operators:
Member Operation Syntax Description Example
__add__ Addition a + b Adds values on either side of the operator. a + b = 30
__sub__ Subtraction a - b Subtracts right hand operand from left hand operand. a – b = -10
__mul__ Multiplication a * b Multiplies values on either side of the operator. a * b = 200
__truediv__ Division a / b Divides left hand operand by right hand operand. b / a = 2
__neg__ Negation -a Return the value negated. a = -b
__pos__ Positive +a Return value positive. a = +b
__eq__ Equality a == b If the values of two operands are equal, then the condition becomes true. (a == b) is not true.
__ne__ Difference a != b If values of two operands are not equal, then condition becomes true. (a != b) is true.
__lt__ Less Than a < b If the value of left operand is less than the value of right operand, then condition becomes true. (a < b) is true.
__iadd__ Addition (Inplace) a += b It adds right operand to the left operand and assign the result to left operand. c += a is equivalent to c = c + a
__isub__ Subtraction (Inplace) a -= b It subtracts right operand from the left operand and assign the result to left operand. c -= a is equivalent to c = c - a
__imul__ Multiply (Inplace) a *= b It multiplies right operand with the left operand and assign the result to left operand. c *= a is equivalent to c = c * a
__itruediv__ Divide (Inplace) a /= b It divides left operand with the right operand and assign the result to left operand. c /= a is equivalent to c = c / ac /= a is equivalent to c = c / a
Member Functions
A
RLPy.RColor.A ( self, args )
Get the value of the color-Alpha.
Returns
The value of the color-Alpha - float
AdjustHSBC
RLPy.RColor.AdjustHSBC ( self, fHue, fSaturate, fBrightness, fContrast, bInvert )
Use HSBC way to adjust the color.
Parameters
fHue [in] Hue value - float
fSaturate [in] Saturate value - float
fBrightness [in] Brightness value - float
fContrast [in] Contrast value - float
bInvert [in] If invert - bool
AdjustRGBA
RLPy.RColor.AdjustRGBA ( self, fRed, fGreen, fBlue, fAlpha, bInvert )
Use RGBA way to adjust the color.
Parameters
fRed [in] Red value - float
fGreen [in] Green value - float
fBlue [in] Blue value - float
fAlpha [in] Alpha value - float
Alpha
RLPy.RColor.Alpha ( self )
Returns
The value of the color-Alpha(value: 0~255) - int
B
RLPy.RColor.B ( self, args )
Get the value of the color-Blue.
Returns
The value of the color-Blue - float
Blue
RLPy.RColor.Blue ( self )
Returns
The value of the color-Blue(value: 0~255) - int
From
RLPy.RColor.From ( self, r, g, b, a )
Convert unsigned char rgba data to CColor.
Parameters
r [IN] the unsigned char value of red - string
g [IN] the unsigned char value of green - string
b [IN] the unsigned char value of blue - string
a [IN] the unsigned char value of alpha - string
Returns
The CRgb data - RLPy.RColor
FromARGB
RLPy.RColor.FromARGB ( self, arg2 )
Convert ARGB to CColor.
Parameters
[IN] the unsigned long ARGB value.
Returns
The CColor data - RLPy.RColor
FromCOLORREF
RLPy.RColor.FromCOLORREF ( self, arg2 )
Convert COLORREF to CColor.
Parameters
[IN] the unsigned long COLORREF value.
Returns
FromHSL
RLPy.RColor.FromHSL ( self, fHue, fSaturate, fLevel )
Convert the HSL data to rgba data.
Parameters
fLevel [in] Lightness value - float
G
RLPy.RColor.G ( self, args )
Get the value of the color-Green.
Returns
The value of the color-Green - float
GammaCorrect
RLPy.RColor.GammaCorrect ( self, fGamma )
Returns the gamma value.
Returns
The gamma value of the rgba data - RLPy.RColor
Green
RLPy.RColor.Green ( self )
Returns
The value of the color-Green(value: 0~255) - int
Normalize
RLPy.RColor.Normalize ( self )
Normalizes this rgba vector.
Returns
The normalized rgba vector - RLPy.RColor
R
RLPy.RColor.R ( self, args )
Get the value of the color-Red.
Returns
The value of the color-Red - float
Red
RLPy.RColor.Red ( self )
Returns
The value of the color-Red(value: 0~255) - int
Saturate
RLPy.RColor.Saturate ( self )
Saturates this rgba vector.
Returns
The saturated rgba vector - RLPy.RColor
ToARGB
RLPy.RColor.ToARGB ( self )
Convert CColor to ARGB.
Returns
The ARGB data - int
ToCOLORREF
RLPy.RColor.ToCOLORREF ( self )
Convert CColor to COLORREF.
Returns
The COLORREF data - int
ToGrayScale
RLPy.RColor.ToGrayScale ( self )
Returns gray scale.
Returns
The gray scale - float
ToHSL
RLPy.RColor.ToHSL ( self, fHue, fSaturate, fLevel )
Convert the rgba data to HSL data.
Parameters
fHue [OUT] Hue value - float
fSaturate [OUT] Saturate value - float
fLevel [OUT] Lightness value - float
