IC Python API:RLPy RILight
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/15/2020
Description
This is the base class for all light sources and provides settings for some basic properties, e.g. active states, strength, color values, etc. It also provides a Transform Control with the ability to set translation, rotation, and scale keys.
Inheritance
RIBase > RIObject > RILight
RILight > SpotLight | PointLight | DirectionalLight
Member Functions
SetActive ( self, bActive )
Set the active state for the light.
See Also: GetActive
Parameters
bActive [IN] The active state - bool
1 # Get light object
2 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Spotlight")
3
4 # Set light object active status
5 light_object.SetActive(True)
GetActive ( self )
Get the active state of the light.
See Also: SetActive
Returns
Whether or not the light is active - bool
3
4 # Get light object active status
5 active_status = light_object.GetActive()
6 print(active_status)
SetMultiplier ( self, kTime, fMultiplier )
Set the light's strength value at a given time.
See Also: GetMultiplier
Parameters
kTime [IN] Time at which to set the light's strength value - RTime
fMultiplier [IN] The strength value - float
Returns
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
3
4 # Set light object multiplier value
5 result = light_object.SetMultiplier(RLPy.RTime(0), 8.0)
GetMultiplier ( self )
Get the light's current strength.
See Also: SetMultiplier
Returns
The strength of the light - float
3
4 # Get light object multiplier value
5 multiplier_value = light_object.GetMultiplier()
6 print(multiplier_value)
SetColor ( self, kTime, kColor )
Set the light's color at a given time.
See Also: GetColor
Parameters
kTime [IN] Time at which to set the light's color - RTime
kColor [IN] The target color for the light - RRgb
Returns
3
4 # Set light object color value
5 result = light_object.SetColor(RLPy.RTime(0), RLPy.RRgb.RED)
GetColor ( self )
Get the light's color at a given time.
See Also: SetColor
Returns
The light's color in RRgb - RRgb
3
5 light_color = light_object.GetColor()
6 print(light_color)
