IC Python API:RLPy RAudio
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules.
Detailed Description
This is a utility class providing methods to manipulate audio files.
( Experimental Class )
# load audio by path
selection_list = RLPy.RScene.GetAvatars()
avatar = selection_list[0]
wav_file = "C://SpecialDay.wav"
print(RLPy.RAudio.LoadAudioToObject(avatar, wav_file, RLPy.RTime(600)))
# load audio by audio object
empty_object = RLPy.RAudio.CreateAudioObject()
empty_object.Load(wav_file)
print(RLPy.RAudio.LoadAudioToObject(avatar, empty_object, RLPy.RTime(600)))
Member Functions
CreateAudioObject
RLPy.RAudio.CreateAudioObject ( )
Returns the audio instance.
Returns
RIAudioObject - RLPy.RIAudioObject
LoadAudioToObject
RLPy.RAudio.LoadAudioToObject ( args )
Load audio to the target object and return audio length according to audio object.
Parameters
spObject [IN] load to which object (object can be avatar, prop) - RLPy.RIObject
pAudioObject [IN] audio object store wave - RLPy.RIAudioObject
kStartTime [IN] the audio start time in the application in sec - RLPy.RTime
nLoopCount [IN] audio loop count, default is 1 - int
kFadeIn [IN] fade-in in sec, default is 0 - RLPy.RTime
kFadeOut [IN] fade-out in sec, default is 0 - RLPy.RTime
kCutLength [IN] cut-length in sec, default is 0 - RLPy.RTime
Returns
Audio length. If loaded failed return 0.0f - float
