IC Python API:RLPy RTransform
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/13/2020
Description
This class represent the object transform matrix data. This class provides access to RLPy's internal 4x4 matrix operators and related functions.
See also: RMatrix4
Operators
The "addition" operator.
See Also: +=
 1 matrix_a = RLPy.RMatrix4( 2, 0, 0, 0,
 2                           0, 2, 0, 0,
 3                           0, 0, 2, 0,
 4                           1, 2, 3, 1 )
 5 matrix_b = RLPy.RMatrix4( 3, 0, 0, 0,
 6                           0, 3, 0, 0,
 7                           0, 0, 3, 0,
 8                           2, 2, 2, 1 )
 9 transform =  RLPy.RTransform().From( matrix_a ) + RLPy.RTransform().From( matrix_b )
10
11 print( transform.Matrix().GetRow(0)[0] == 2*3 ) # true
12 print( transform.Matrix().GetRow(1)[1] == 2*3 ) # true
13 print( transform.Matrix().GetRow(2)[2] == 2*3 ) # true
14 print( transform.Matrix().GetRow(3)[0] == 1+2 ) # true
15 print( transform.Matrix().GetRow(3)[1] == 2+2 ) # true
16 print( transform.Matrix().GetRow(3)[2] == 3+2 ) # true
The "equal to" operator.
See Also: !=
1 transform_identity = RLPy.RTransform(RLPy.RTransform.IDENTITY)
2 print( transform_identity == transform_identity ) # true
The "not equal to" operator.
See Also: ==
2 print( transform_identity != transform_identity ) # false
The "addition assignment" operator.
See Also: +
 2                           0, 2, 0, 0,
 3                           0, 0, 2, 0,
 4                           1, 2, 3, 1 )
 6                           0, 3, 0, 0,
 7                           0, 0, 3, 0,
 8                           2, 2, 2, 1 )
10 transform += RLPy.RTransform().From( matrix_b )
11
12 print( transform.Matrix().GetRow(0)[0] == 2*3 ) # true
13 print( transform.Matrix().GetRow(1)[1] == 2*3 ) # true
14 print( transform.Matrix().GetRow(2)[2] == 2*3 ) # true
15 print( transform.Matrix().GetRow(3)[0] == 1+2 ) # true
16 print( transform.Matrix().GetRow(3)[1] == 2+2 ) # true
17 print( transform.Matrix().GetRow(3)[2] == 3+2 ) # true
Member Functions
D (self, args)
Get the determinate sign of this transform matrix.
Returns
Returns the value of determinate sign - float
2 print(transform_identity.D()) # <Swig Object of type 'float *' at 0x0000027B8A2D1FC0>
S (self, args)
Get the Scale of this transform matrix.
Returns
The value of scale in 3D vector - RVector3
 1 d_determinate = 0
 2 s_scale       = RLPy.RVector3( RLPy.RVector3.ZERO )
 3 u_stretch     = RLPy.RQuaternion( RLPy.RQuaternion.IDENTITY )
 4 r_rotate      = RLPy.RQuaternion( RLPy.RQuaternion.IDENTITY )
 5 t_translate   = RLPy.RVector3( RLPy.RVector3.ZERO )
 6
 7 s_scale.x = 1
 8 s_scale.y = 2
 9 s_scale.z = 3
10 transform_data = RLPy.RTransform(d_determinate,s_scale,u_stretch,r_rotate,t_translate )
11
12 print( transform_data.S().x ) # 1
13 print( transform_data.S().y ) # 2
14 print( transform_data.S().z ) # 3
U (self, args)
Get the stretch of this transform matrix.
Returns
The value of stretch in quaternion - RQuaternion
 1 d_determinate = 0
 6
 7 u_stretch.x = 4
 8 u_stretch.y = 5
 9 u_stretch.z = 6
10 u_stretch.w = 7
11 transform_data = RLPy.RTransform(d_determinate,s_scale,u_stretch,r_rotate,t_translate )
12
13 print( transform_data.U().x ) # 4
14 print( transform_data.U().y ) # 5
15 print( transform_data.U().z ) # 6
16 print( transform_data.U().w ) # 7
R (self, args)
Get the rotation of this transform matrix.
Returns
The value of rotation in quaternion - RQuaternion
 1 d_determinate = 0
 6
 7 r_rotate.x = 8
 8 r_rotate.y = 9
 9 r_rotate.z = 10
10 r_rotate.w = 11
12
13 print( transform_data.R().x ) # 8
14 print( transform_data.R().y ) # 9
15 print( transform_data.R().z ) # 10
16 print( transform_data.R().w ) # 11
T (self, args)
Get the translation of this transform matrix.
Returns
The value of translation in 3D vector - RVector3.
 1 d_determinate = 0
 6
 7 t_translate.x = 12
 8 t_translate.y = 13
 9 t_translate.z = 14
11
12 print( transform_data.T().x ) # 12
13 print( transform_data.T().y ) # 13
14 print( transform_data.T().z ) # 14
AlmostEquel (self, kRts)
Check if this and another transform is almost equal.
Parameters
kRts [IN] The transform - RTransform
Returns
True if this and another transform is almost equal, else False - bool
1 matrix4 = RLPy.RMatrix4(-1, 0, 0, 0,
2                          0,-1, 0, 0,
3                          0, 0, 1, 0,
4                         -1, 1, 1, 1 )
5
6 transform1  = RLPy.RTransform().From( matrix4 )
7 transform2  = RLPy.RTransform().From( matrix4 )
8
9 print( transform1.AlmostEquel( transform2 )) # True
Inverse (self)
Get the inverse of this transform.
Returns
The inverse of this transform - RTransform
2                          0,-1, 0, 0,
3                          0, 0, 1, 0,
4                         -1, 1, 1, 1 )
5
6 transform = RLPy.RTransform().From( matrix4 )
7 print( transform.Matrix().GetRow(0)[0] )
8 print( transform.Matrix().GetRow(0)[1] )
From (self, mMatrix)
Set this transform from a 4x4 matrix.
Returns
A transform composited from 4x4 matrix - RTransform
2                          0,-1, 0, 0,
3                          0, 0, 1, 0,
4                         -1, 1, 1, 1 )
5 transform = RLPy.RTransform().From( matrix4 )
6
Matrix (self)
Get 4x4 matrix from this transform.
Returns
A 4x4 matrix - RMatrix4
1 matrix4 = RLPy.RMatrix4( 0,-1, 0, 0,
2                         -1, 0, 0, 0,
3                          0, 0,-1, 0,
4                          1,-2, 1, 1 )
5 transform_data = RLPy.RTransform().From( matrix4 )
6 transform_data_matrix = transform_data.Matrix()
7
8 print( transform_data_matrix.GetRow(0)[0] )
9 print( transform_data_matrix.GetRow(0)[1] )
IsIdentity (self)
Check if this transform is equal to identity transform. Identity transform corresponds to "no transform" - the object is perfectly aligned with the world or parent axes and positioned at the origin.
Returns
True if the transform is equal to identity transform, else False - bool
1 matrix4 = RLPy.RMatrix4( 1, 0, 0, 0,
2                          0, 1, 0, 0,
3                          0, 0, 1, 0,
4                          0, 0, 0, 1 )
6 print( transform_data.IsIdentity() ) # True
Scale (self)
Form a scale matrix from this transform.
Returns
A 3x3 scale matrix from this transform - RMatrix3
1 scale = RLPy.RVector3( 4, 5, 6 )
2 matrix4 = RLPy.RMatrix4().FromRTS( RLPy.RMatrix3.IDENTITY,
3                                        RLPy.RVector3.UNIT_XYZ,
4                                        scale )
6
7 print( transform_data.Scale().GetRow(0)[0] ) # 4
8 print( transform_data.Scale().GetRow(1)[1] ) # 5
9 print( transform_data.Scale().GetRow(2)[2] ) # 6
Rotate (self)
Form a rotate matrix from this transform.
Returns
A 3x3 rotate matrix from this transform - RMatrix3
1 rotate = RLPy.RMatrix3( 0.8137977, -0.4698463,  0.3420202,
2                            0.5438381,  0.8231729, -0.1631759,
3                           -0.2048741,  0.3187958,  0.9254166 )
4 matrix4  = RLPy.RMatrix4().FromRTS( [[#Rotate (self)|Rotate]], RLPy.RVector3.UNIT_XYZ , RLPy.RVector3.UNIT_XYZ )
6
7 print( transform_data.Rotate().GetRow(0)[0] )
8 print( transform_data.Rotate().GetRow(0)[1] )
9 print( transform_data.Rotate().GetRow(0)[2] )
GetSR (self)
Form a 3x3 matrix with rotation and scale from this transform.
Returns
A 3x3 matrix from this transform - RMatrix3
 1 scale  = RLPy.RVector3( 2, 2, 2 )
 2 rotate = RLPy.RMatrix3( -0,-0, 1,
 3                         -1,-0, 0,
 4                         0,-1,-0 )
 5 matrix4 = RLPy.RMatrix4().FromRTS( [[#Rotate (self)|Rotate]], RLPy.RVector3.UNIT_XYZ , scale )
 6 transform_data = RLPy.RTransform().From( matrix4 )
 7
 8 print( transform_data.GetSR().GetRow(0)[0] ) # -0*2 = 0
 9 print( transform_data.GetSR().GetRow(0)[1] ) # -0*2 = 0
10 print( transform_data.GetSR().GetRow(0)[2] ) #  1*2 = 2
