IC Python API:RLPy RIVisemeComponent
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/22/2020
Description
This class provides viseme related operations including reading an audio source and creating a viseme clip out of it. It can also add and remove keys from the viseme clip as well as provide Text-to-Speech capabilities. A viseme track within the timeline will show viseme clips and mouth shapes (viseme keys). The lip options track also includes the viseme smooth clip which can be used to smooth out the transition between the different mouth shapes in the event of a lip-sync animation.
Viseme keys in the "Lips" track.
Member Functions
LoadVocal ( self, pAudio, kStartTime, strClipName )
Create a viseme clip for this character with a given audio source.
Parameters
pAudio [IN] Audio source object - RIAudioObject
kStartTime [IN] Clip start time - RTime
strClipName [IN] Clip name - str
Return
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
 1 # Get avatar viseme component
 2 avatar_list = RLPy.RScene.GetAvatars()
 3 avatar = avatar_list[0]
 4 viseme_component = avatar.GetVisemeComponent()
 5
 6 # Load vocal with create audio object
 7 audio = RLPy.RAudio.CreateAudioObject()
 8 audio_path = "./SpecialDay.wav"
 9 start_time = RLPy.RGlobal.GetTime()
10 RLPy.RAudio.LoadAudioToObject(avatar, audio_path, start_time)
11 clip_name = "Default"
12 result = viseme_component.LoadVocal(audio, start_time, clip_name)
13
14 # Load vocal with audio recorder
15 audio_recorder = RLPy.RAudioRecorder()
16 audio_recorder.Start()
17 audio_recorder.Stop()
18 audio_source = audio_recorder.GetAudio()
19 start_time = RLPy.RGlobal.GetTime()
20 clip_name = "Default"
21 result = viseme_component.LoadVocal(audio_source, start_time, clip_name)
AddVisemeOptionClip ( self, kSmoothOption, kStartTime, strClipName )
Add a viseme smooth settings clip to the character. If a viseme clip does not exist at the start time, then a viseme smooth clip will not be deployed.
Parameters
kSmoothOption [IN] Viseme smooth option - RVisemeSmoothOption
Return
 5
 6 # Add viseme option clip
 7 smooth_option = RLPy.RVisemeSmoothOption()
 8 smooth_option.SetStrengthEnable(True, True, True)
 9 smooth_option.SetStrengthValue(0, 0, 1)
10 start_time = RLPy.RGlobal.GetTime()
12 result = viseme_component.AddVisemeOptionClip(smooth_option, start_time, clip_name)
AddVisemeKey ( self, kKey )
Add a viseme key inside the current viseme clip. If the strength value of the viseme key lies outside of the range (0-100), or if a viseme clip does not exist then return RLPy.RStatus.Failure.
See Also: RemoveVisemesKey
Parameters
kKey [IN] The viseme key to be added. - RVisemeKey
Return
 5
 6 # Add viseme key
 7 Key = RLPy.RVisemeKey()
 8 key.SetTime(RLPy.RTime(0))
 9 key.SetID(RLPy.EVisemeID_AH)
10 key.SetWeight(50)
11 result = viseme_component.AddVisemeKey(key)
AddVisemesClip ( self, kTime, nClipName, kClipLength )
Add an empty viseme clip to the character.
See Also: RemoveVisemesClip
Parameters
kTime [IN] Clip start time - RTime
nClipName [IN] Clip name - str
kClipLength [IN] Clip length - RTime
Return
 5
 6 # Add visemes clip
 7 clip_start_time = RLPy.RTime(150)
 8 clip_name = "Clip1"
 9 clip_length = RLPy.RTime(500)
10 result = viseme_component.AddVisemesClip(clip_start_time, clip_name, clip_length)
RemoveVisemesClip ( self, kTime )
Remove a viseme clip on the character at the requested time. If a viseme clip does not exist at the given time then return RLPy.RStatus.Failure.
See Also: AddVisemesClip
Parameters
kTime [IN] Delete viseme clip at the specified time - RTime
Return
5
6 # Remove a viseme clip at 1000 ms
7 result = viseme_component.RemoveVisemesClip(RLPy.RTime(1000))
RemoveVisemesKey ( self, kKey )
Delete a viseme key within a viseme clip at the given time. If a viseme clip is missing or a viseme key does not exist at the given time, then return RLPy.RStatus.Failure.
Parameters
kTime [IN] Delete the key at the specified time within a viseme clip - RTime
Return
 5
 6 # Remove visemes key
 7 key = RLPy.RVisemeKey()
 8 key.SetTime(RLPy.RTime(300))
10 key.SetWeight(80)
11 result = viseme_component.RemoveVisemesKey(key)
GetVisemeMorphWeights ( self )
Get all of the viseme morph weights on this character.
Returns
Viseme morph weights - float list
5
6 # Get viseme morph weights
7 viseme_weights = viseme_component .GetVisemeMorphWeights()
GetVisemeBones ( self )
Get all of the viseme bone joints on this character.
Returns
Return all of the viseme bone joints - RINode list
5
6 # Get viseme bones
7 viseme_bones = viseme_component.GetVisemeBones()
GetVisemeKeys ( self )
Get all the viseme keys inside all of the viseme clips on this character.
See Also: GetVisemeKey
Returns
All of the viseme keys of all the viseme clips - RVisemeKey list
5
6 # Get viseme keys
7 viseme_key_list = viseme_component.GetVisemeKeys()
GetVisemeKey ( self, kTime, kKey )
Get the viseme key for the given time. If a viseme clip does not exist then return RLPy.RStatus.Failure.
See Also: GetVisemeKeys
Parameters
kTime [IN] Query the viseme key at the specified time - RTime
kKey [OUT] Viseme key at the specified time - RVisemeKey
Return
5
6 # Get viseme key
7 ret_key = RLPy.RVisemeKey()
8 result = viseme_component.GetVisemeKey(RLPy.RTime(0), ret_key)
TextToSpeech ( self, strContent, eLanguage, fVolume, fPitch, fSpeed )
Create a viseme clip from script processed through text-to-speech;
See Also: TextToVisemeData
Parameters
strContent [IN] Content of speech - string
eLanguage [IN] Language of speech system. - RLPy.ELanguage enum
  • RLPy.ELanguage_TW - The input text is in the Chinese language family.
  • RLPy.ELanguage_US - The input text is in the English language family.
fVolume [IN] Settings of Volume [0.0,100.0]
fPitch [IN] Settings of Pitch [0.0,100.0]
fSpeed [IN] Settings of Speed [0.0,100.0]
Return
5
6 # Text to speech
7 result = viseme_component.TextToSpeech("speech", RLPy.ELanguage_US, 100, 50, 50)
TextToVisemeData ( self, strContent, fVolume, fPitch, fSpeed )
When this character is provided a script processed by Text-To-Speech (TTS); Use this function can retrieve all the viseme IDs along with their corresponding times.
See Also: TextToSpeech
Parameters
strContent [IN] Content of speech.
Returns
All viseme IDs along with their corresponding times.
5
6 # Text to viseme data
7 result = viseme_component.TextToVisemeData("speech", 100, 50, 50)
GetStrength ( self )
Get the viseme strength value.
Returns
Viseme strength value - float
5
6 # Get viseme strength
7 strength = viseme_component.GetStrength()
