IC Python API:RLPy RPyTimer
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/14/2020
Description
This class is used to setup a timed event. Use SetInterval and GetInterval to access and set the time interval. Use SetSingleShot and IsSingleShot to access and set the trigger state (single shot or repeatly trigger). Use Start, Stop, and IsRunning to control the execution of the Timer.
In order to receive trigger events, first create a new class and inherit from RPyTimerCallback and register with RegisterPyTimerCallback. When not in use, you can unregister the timer event with UnRegisterPyTimerCallback.
See Also: RPyTimerCallback.
 1 class MyPyTimerCallback(RLPy.RPyTimerCallback):
 2    def __init__(self):
 3        RLPy.RPyTimerCallback.__init__(self)
 4    def Timeout(self):
 5        print ("timeout")
 6
 7 # Set Timer
 8 timer = RLPy.RPyTimer()
 9 timer.SetInterval(100)
10 timer.SetSingleShot(True)
11 print(timer.GetInterval())  # 100
12 # Register the callback
13 timer_callback = MyPyTimerCallback()
14 timer.RegisterPyTimerCallback(timer_callback)
15 # Start the Timer
16 timer.Start()
17 # Unregister the callback
18 timer.UnregisterPyTimerCallback()
Member Functions
GetInterval ( self )
Get the time interval for the event triggered by the timer in milliseconds. The default interval value is 0, which will cause the timer to start triggering immediately after Start.
See Also: SetInterval
Returns
Timer interval ( milisecond ) - int
1 timer = RLPy.RPyTimer()
2 timer.SetInterval(1000)
3 print (timer.GetInterval())	# 1000
IsRunning ( self )
Check if the Timer is currently running.
See Also: Start, Stop
Returns
True if the timer is currenlty running, else False - bool
2 timer.Start()
3 print (timer.IsRunning())	# True
IsSingleShot ( self )
Get the Timer trigger settings. Return True if the trigger is single-shot and False for repeat trigger.
See Also: SetSingleShot
Returns
True if trigger is single-shot, else False - bool
2 timer.SetSingleShot(True)
3 print (timer.IsSingleShot())	# True
RegisterPyTimerCallback ( self, pCallback )
Register a Callback object with the Timer.
See Also: UnregisterPyTimerCallback
Parameters
pCallback [IN] Callback object inherited from RPyTimerCallback- RPyTimerCallback
5        print ("timeout")
6
7 timer = RLPy.RPyTimer()
8 timer_callback = MyPyTimerCallback()
9 timer.RegisterPyTimerCallback(timer_callback)
UnregisterPyTimerCallback ( self, pCallback )
Unregister the Callback object for the Timer.
See Also: RegisterPyTimerCallback
 5        print ("timeout")
 6
10 # unregister callback
11 timer.UnregisterPyTimerCallback()
SetInterval ( self, nMSec )
Set the Timer trigger interval in milliseconds. The default interval value is 0, which will cause the timer to start triggering immediately after Start().
See Also: GetInterval
Parameters
nMSec [IN] Timer interval in milliseconds - int
SetSingleShot ( self, bSingleShot )
Set the Timer trigger state. Single-shot will only fire off the trigger event once, otherwise the event will fire off according to the Timer interval. The default setting is False.
See Also: IsSingleShot
Parameters
bSingleShot [IN] Set to single-shot triggering - bool
Start ( self )
Start or restart the Timer. If the Timer is already running, then this operation will stop the Timer first then start it again. If the trigger is set to single-shot then the Timer event will activate one more time.
2 timer.SetInterval(100)
3 timer.Start()
Stop ( self )
Stop the Timer.
3 timer.Start()
4 # do something
5 timer.Stop()
