IC Python API:RLPy RTime
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 05/12/2020
Description
This class represents the midst unit (a.k.a unit of time) in animation. Currently, it provides two states: milliseconds and 60FPS (frames per second). When you create an animation key, you'll need to set the value according to the incoming time. This class also provides different unit conversions such as GetFrameIndex, IndexedFrameTime, and GetFrameTime to ensure that the time retrieved is aligned with animation frames.
Operators
The "equal to" operator. Check if two time objects are equal.
Returns
True if the values of the two time objects are equal, else False.
See Also: !=
 1 # Equivalence operator
 2 time1 = RLPy.RTime(3000)
 3 time2 = RLPy.RTime(3000)
 4 print(time1 == time2)
 5
 6 # Compare current time
 7 time = RLPy.RGlobal.GetTime()
 8
 9 if time == RLPy.RGlobal.SetTime(RLPy.RTime(1000)):
10    print("equal")
11 elif time > RLPy.RGlobal.SetTime(RLPy.RTime(1000)):
12    print("greater")
13 elif time < RLPy.RGlobal.SetTime(RLPy.RTime(1000)):
14    print("less")
The "not equal to" operator. Check if two time object are not equal.
Returns
True if the values of the two time objects are not equal, otherwise return False.
See Also: ==
1 # Not equal operator
3 time2 = RLPy.RTime(3000, RLPy.k60FPS)
4 print(time1 != time2)
The "less than" operator. Check if a time object is less than another.
Returns
True if this value is less than or equal to another RTimevalue, else False.
See Also: <=
1 # Less equal operator
2 time1 = RLPy.RTime(1000)
3 time2 = RLPy.RTime(2000)
4 print(time1 <= time2)
The "greater than or equal" operator. Check if a time object is greater than or equal to another.
Returns
True if this RTimevalue is greater than or equal to another RTimevalue, else False.
See Also: >
2 time1 = RLPy.RTime(2000)
3 time2 = RLPy.RTime(1000)
4 print(time1 >= time2)
Returns
True if this RTimevalue is less than another RTimevalue, else False.
1 # Less than operator
4 print(time1 < time2)
The "greater than" operator. Check if a time object is greater than another.
Returns
True if this RTimevalue is greater than another RTimevalue, else False.
See Also: >=
1 # Greater than operator
4 print(time1 > time2)
The addition operator. Add two time objects together.
Returns
Sum of the two time objects - RTime
See Also: +=
1 # Addition operator
4 time3 = time1 + time2
5 print(time3)
The "addition assignment" operator. Add a time object to this time object.
Returns
Sum of the two time objects.
See Also: +
1 # Addition assignment operator
4 time1 += time2
5 print(time1)
The 'subtraction' operator. Minus a time object from another.
Returns
Difference of the two time objects - RTime
See Also: -=
1 # Subtraction operator
4 time3 = time2 - time1
5 print(time3)
The "subtraction assignment" operator. Subtract a time object from this time object.
Returns
See Also: -
1 # Subtraction assignment operator
4 time2 -= time1
5 print(time2)
The "multiplication" operator. Multiply two time objects.
Returns
Time object with the multiplied value - RTime
See Also: *=
1 # Multiplication operator
2 time1 = RLPy.RTime(100.0)
3 time2 = time1 * 0.5
4 print(time2)
The "multiplication assignment" operator. Mutliply a time object to this time object.
Returns
Time object with the product value - RTime
See Also: *
1 # Multiplication assignment operator
2 time1 = RLPy.RTime(200.0)
3 time1 *= 1.5
4 print(time1)
The "division" operator. Divide two time objects.
Returns
Time object with the quotient value - RTime
See Also: /=
1 # Division operator
3 time2 = time1 / 150
4 print(time2)
The "division assignment" operator. Divide a time object from this time object.
Returns
See Also: /
1 # Division assignment operator
2 time1 = RLPy.RTime(3000.0)
3 time1 /= 15
4 print(time1)
Member Functions
__init__ ( self, args )
This operation creates a time object instance.
1 # Constructor RTime object
2 time1 = RLPy.RTime()
3
4 # Constructor RTime object with RTime object
5 time2 = RLPy.RTime(time1)
6
7 # Constructor RTime object with float value and unit
8 time3 = RLPy.RTime(0, RLPy.kMilliseconds)
GetUnit ( self )
Get the midst unit for the time object.
See Also: SetUnit( self, eUnit )
Returns
Midst unit of a given time object - RLPy.Unit
1 # Get time unit
2 time = RLPy.RTime(0, RLPy.kMilliseconds)
3 time_unit = time.GetUnit()
4 print(time_unit)
GetValue ( self )
Get the time value of the time object.
See Also: SetValue( self, fValue )
Returns
Time value of the time object - float
1 # Get time value
2 time = RLPy.RTime(3000)
3 time_value = time.GetValue()
4 print(time_value)
SetUnit ( self, eUnit )
Set the midst unit for the time object.
See Also: GetUnit( self )
Parameters
eUnit [IN] Midst unit - RLPy.Unit
1 # Set time unit
2 time = RLPy.RTime(0)
3 time.SetUnit(RLPy.k60FPS)
SetValue ( self, fValue )
Set the time value for the time object.
See Also: GetValue( self )
Parameters
fValue [IN] Time value - float
1 # Set time value
3 time.SetValue(3000)
AsUnits ( self, eUnit )
Convert the time value to a specified midst unit without changing it for the time object.
Returns
The converted time value of the time object in the specified midst unit - float
1 # As units milliseconds
2 time = RLPy.RTime(2000)
3 time_value = time.AsUnits(RLPy.kMilliseconds)
GetFrameIndex ( self, kTime, nFps )
Get the frame index of a given time based on a specified FPS.
Parameters
kTime [IN] animation time - RTime
nFps [IN] frames per second - integer
Returns
The corresponding frame index - integer
1 # Get frame index
2 frame_index = RLPy.RTime.GetFrameIndex(RLPy.RTime(3000.0), 60)
3 print(frame_index)
IndexedFrameTime ( self, nFrameIndex, nFps )
Get the time of a given frame index based on a specified FPS.
Parameters
nFrameIndex [IN] input frame index - integer
Returns
The corresponding time - RTime
1 # Get indexed frame time
2 frame_time = RLPy.RTime.IndexedFrameTime(180, 60)
3 print(frame_time)
GetFrameTime ( self, kTime, nFps )
Checks if the input time falls on a specific frame based on the input FPS. If the time does not match up correctly with any frame, then return the time of the nearest frame. This ensures that the return value will always align to a specific animation frame.
Parameters
Returns
1 # Get frame time
2 frame_time = RLPy.RTime.GetFrameTime(RLPy.RTime(3002), 60)
3 print(time2)
