IC Python API:RLPy RIMorphComponent
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/16/2020
Description
This class can edit morph animation keys and retrieve morph weights on a target Avatar or Prop. A specific mesh name must be provided for the functions of this class, because every mesh can carry multiple morph targets. This class can only be used with RIProp and RIAvatar.
Inheritance
RIBase > RIMorphComponent
Member Functions
AddKey ( self, strMeshName, strMorphName, kTime, fWeight, bSendEvent, bPauseAP )
See also: RTime, RStatus, GetWeight
Parameters
strMeshName [IN] Mesh name - string
strMorphName [IN] Name of a morph applied to the mesh - string
kTime [IN] Point in time for applying the key - RTime
fWeight [IN] The weight for the morph key - float
bSendEvent [IN] Whether the key creation will broadcast an application-level event - bool
bPauseAP [IN] Whether the key creation will pause the application - bool
Return
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
1 avatar_list = RLPy.RScene.GetAvatars()
2 morph_component = avatar_list[0].GetMorphComponent()
3 result = morph_component.AddKey( "your_mesh_name", "your_morph_name", RLPy.RTime(67), 0.5, False, False )
GetMorphNames ( self, strMeshName )
Get all the morph target names for a given mesh on this morph component.
See also: RIAvatar
Parameters
strMeshName [IN] Name for the mesh with morphs applied - string
Returns
List of names for all of the morphs applied to the mesh - string list
3 morph_names = morph_component.GetMorphNames("your_mesh_name")
4 for _name in morph_names:
5     print(_name)
GetWeight ( self, strMeshName, strMorphName, kTime, fWeight )
Get the morph target weight for a given mesh and morph name at the requested time on this morph component.
See also: AddKey, RTime, RStatus
Parameters
strMeshName [IN] Name of the mesh that contains the morph target - string
strMorphName [IN] Name of a morph target for retrieving the morph weight at a specified time - string
kTime [IN] Point in time for retrieving the morph weight value - RTime
fWeight [OUT] Return the morph weight for the mesh morph target - float
Return
3 f_ret_weight = 0
4 return_list = morph_component.GetWeight( "your_mesh_name", "your_morph_name", RLPy.RTime(67), f_ret_weight )
5 f_ret_weight = return_list[1]
6 print(f_ret_weight) # is 0.5
RemoveAllKeys ( self, strMeshName, strMorphName )
Remove all morph keys for a given mesh and morph name on this morph component.
See also: AddKey, RStatus
Parameters
strMeshName [IN] Mesh name for morph key deletion - string
strMorphName [IN] Morph name for morph key deletion - string
Return
3 result = morph_component.RemoveAllKeys("your_mesh_name", "your_morph_name")
