IC Python API:RLPy RIMaterialComponent
From Reallusion Wiki!
Jump to: navigation, search
Contents
Main article: Modules.
Last modified: 04/15/2020
Description
This class is used to manipulate material surface properties. The main material properties are Ambient color, Diffuse color, Specular color, Glossiness value, Self-illumination value, Opacity value, textures, and more. A material is affiliated with an object, therefore, member functions of this class must specify a mesh and material name.
Inheritance
RIBase > RIMaterialComponent
Member Functions
AddAmbientKey ( self, kKey, strMeshName, strMaterialName, kColor )
Add an Ambient key for the material according to the time and Transition Type of kKey.
See Also: AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
kKey [IN] The key for time and transition control - RKey
strMeshName [IN] Name of the mesh - string
strMaterialName [IN] Name of a mesh material - string
kColor [IN] The color of a material’s ambient component - RRgb
Returns
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
 1 # Get object, mesh and material
 2 avatar_list = RLPy.RScene.GetAvatars()
 3 avatar = avatar_list[0]
 4 material_component = avatar.GetMaterialComponent()
 5 mesh_list = avatar.GetMeshNames()
 6 mesh_name = mesh_list[0]
 7 material_list = material_component.GetMaterialNames(mesh_name)
 8 material_name = material_list[0]
 9 # Create a key
10 key = RLPy.RKey()
11 key.SetTime(RLPy.RTime(1200))
12 # Add an ambient key value
13 material_component.AddAmbientKey(key, mesh_name, material_name, RLPy.RRgb.RED)
AddDiffuseKey ( self, kKey, strMeshName, strMaterialName, kColor )
Add a Diffuse key for the material according to the time and Transition Type of kKey.
See Also: AddAmbientKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
kKey [IN] The key to add a diffuse key value - RKey
kColor [IN] The color for diffuse - RRgb
Returns
 9 # Create a key
12 # Add a diffuse key value
13 material_component.AddDiffuseKey(key, mesh_name, material_name, RLPy.RRgb.RED)
AddGlossinessKey ( self, kKey, strMeshName, strMaterialName, fWeight )
Add a Glossiness key for the material according to the time and Transition Type of kKey.
See Also: AddAmbientKey, AddDiffuseKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
fWeight [IN] The weight for glossiness - float [0~100]
Returns
 9 # Create a key
12 # Add a glossiness key value
13 material_component.AddGlossinessKey(key, mesh_name, material_name, 0.5)
AddSpecularKey ( self, kKey, strMeshName, strMaterialName, kColor )
Add a Specular key for the material according to the time and Transition Type of kKey.
See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
kColor [IN] The color for specular - RRgb
Returns
 9 # Create a key
12 # Add a specular key value
13 material_component.AddSpecularKey(key, mesh_name, material_name, RLPy.RRgb.RED)
AddSelfIlluminationKey ( self, kKey, strMeshName, strMaterialName, kColor )
Add a Self-illumination key for the material according to the time and Transition Type of kKey.
See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
strMeshName [IN] Name of the mesh - string strMaterialName [IN] Name of a mesh material - string fWeight [IN] The weight for self-illumination - float [0~100]
Returns
 9 # Create a key
12 # Add a self-illumination key value
13 material_component.AddSelfIlluminationKey(key, mesh_name, material_name, 0.5)
AddOpacityKey ( self, kKey, strMeshName, strMaterialName, fWeight )
Add an Opacity key for the material according to the time and Transition Type of kKey.
See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
fWeight [IN] The weight for opacity - float [0~100]
Returns
 9 # Create a key
12 # Add a opacity key value
13 material_component.AddOpacityKey(key, mesh_name, material_name, 0.5)
AddTextureWeightKey ( self, kKey, strMeshName, strMaterialName, eChannel, fWeight )
Add a Texture Channel Weight key for the material according to the time and Transition Type of kKey.
See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
eChannel [IN] A material texture channel - RLPy.EMaterialTextureChannel
  • RLPy.EMaterialTextureChannel_Metallic
  • RLPy.EMaterialTextureChannel_Diffuse
  • RLPy.EMaterialTextureChannel_Specular
  • RLPy.EMaterialTextureChannel_Shininess
  • RLPy.EMaterialTextureChannel_Glow
  • RLPy.EMaterialTextureChannel_Displacement
  • RLPy.EMaterialTextureChannel_Opacity
  • RLPy.EMaterialTextureChannel_DiffuseBlend
  • RLPy.EMaterialTextureChannel_Bump
  • RLPy.EMaterialTextureChannel_Reflection
  • RLPy.EMaterialTextureChannel_Refraction
  • RLPy.EMaterialTextureChannel_Cube
  • RLPy.EMaterialTextureChannel_AmbientOcclusion
  • RLPy.EMaterialTextureChannel_Quantity
fWeight [IN] The weight for channel - float [0~100] ui 上是 0~100, 傳到核心沒乘 0.01
Returns
 9 # Create a key
12 # Modify texture weight
13 texture_channel = RLPy.EMaterialTextureChannel_Diffuse
14 diffuse_weight = 0.1
15 material_component.AddTextureWeightKey(key, mesh_name, material_name,
16                                        texture_channel, diffuse_weight)
AddUvDataKey ( self, kKey, strMeshName, strMaterialName, eChannel, kUvOffset, kUvTile, fUvRotate )
Add an UV Texture Coordinates key for the material according to the time and Transition Type of kKey. This key can be used to set the texture channel's UV offset, tile, and rotate values.
See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddVideoVolumeKey
Parameters
kUvOffset [IN] The uv's offset for channel - RLPy.RVector2f
kUvTile [IN] The uv's tile for channel - RLPy.RVector2f
fUvRotate [IN] The uv's rotate for channel ( radians) - float
Return
 9 # Create a key
12 # Modify uv data
13 texture_channel = RLPy.EMaterialTextureChannel_Bump
14 uv_offset = RLPy.RVector2(0.1, 0)
15 uv_tile = RLPy.RVector2(1, 1)
16 uv_rotate = 3.14
17 material_component.AddUvDataKey(key, mesh_name, material_name,
18                           texture_channel, uv_offset, uv_tile, uv_rotate)
AddVideoVolumeKey ( self, kKey, strMeshName, strMaterialName, eChannel, fVol, bMute )
Add a Video Volume key for the material according to the time and Transition Type of kKey. This key can be used to set the video material's channel video volume.
Parameters
fVol [IN] The volume of video ( 0-100 ) - float
bMute [IN] mute - bool
Return
 9 # Create a key
12 # Load video to material channel
14 video_file = "C://MaterialVideoTest.mp4"
15 video_volume = 50
16 is_mute = False
17 material_component.LoadVideoToTexture(key, mesh_name, material_name,
18                                       texture_channel, video_file)
19 material_component.AddVideoVolumeKey(key, mesh_name, material_name,
20                                     texture_channel, video_volume, is_mute)
GetAmbientColor ( self, strMeshName, strMaterialName )
Get the material's Ambient color.
See Also: GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
ambient color - RRgb
 9 # Get ambient color
10 print(material_component.GetAmbientColor(mesh_name, material_name))
GetDiffuseColor ( self, strMeshName, strMaterialName)
Get the material's Diffuse color.
See Also: GetAmbientColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
diffuse color - RRgb
 9 # Get diffuse color
10 print(material_component.GetDiffuseColor(mesh_name, material_name))
GetGlossinessWeight ( self, strMeshName, strMaterialName)
Get the material's Glossiness weight.
See Also: GetMaterialNameParameters
Parameters
strMeshName [IN] Name for the mesh - string
strMaterialName [IN] Name of the material on the mesh - string
Returns
weight of specular - float
 9 # Get glossiness weight
10 print(material_component.GetGlossinessWeight(mesh_name, material_name))
GetMaterialNames ( self, strMeshName )
Get all the material names for the mesh.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
material names - string list.
1 # Get Object mesh and material
GetOpacity ( self, strMeshName, strMaterialName )
Get the material opacity value.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
weight of opacity - float
 9 # Get opacity
10 print(material_component.GetOpacity(mesh_name, material_name))
GetSelfIlluminationWeight ( self, strMeshName, strMaterialName )
Get the material's self-illumination weight.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
weight of self-illumination - float
 1 ( Experimental API )
 2 # Get object, mesh and material
 3 avatar_list = RLPy.RScene.GetAvatars()
 4 avatar = avatar_list[0]
 5 material_component = avatar.GetMaterialComponent()
 6 mesh_list = avatar.GetMeshNames()
 7 mesh_name = mesh_list[0]
 8 material_list = material_component.GetMaterialNames(mesh_name)
 9 material_name = material_list[0]
10 # Get self-illumination weight
11 print(material_component.GetSelfIlluminationWeight(mesh_name, material_name))
GetSpecularColor ( self, strMeshName, strMaterialName )
Get the material's Specular color.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
Specular color - RRgb
 9 # Get specular color
10 print(material_component.GetSpecularColor(mesh_name, material_name))
GetSpecularWeight ( self, strMeshName, strMaterialName )
Get the material's Specular weight.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
Returns
Specular weight - float
 9 # Get specular weight
10 print(material_component.GetSpecularWeight(mesh_name, material_name))
GetTextureWeights ( self, strMeshName, strMaterialName )
Get all texture channel weights for the material.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetUvData, GetVideoVolume
Parameters
Returns
Ordered list of all texture channel weights - float list
 9 # Get all texture weights
10 temp_texture_weight_list = material_component.GetTextureWeights(mesh_name, material_name)
11 print(temp_texture_weight_list)
GetUvData ( self, strMeshName, strMaterialName, eChannel, kUvOffest, kUvTile, fUvRotate )
Get all texture channel UV coordinates (offset, tiling, rotation) for the material.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetVideoVolume
Parameters
kUvOffset [OUT] UV offset - RVector2
kUvTile [OUT] UV tiling - RVector2
fUvRotate [OUT] UV rotation in radians- float
Returns
 9 # Get UV data
10 uv_offset = RLPy.RVector2()
11 uv_tile = RLPy.RVector2()
12 uv_rotate = 0.0
13 uv_data = material_component.GetUvData(mesh_name, material_name, texture_channel, uv_offset, uv_tile, uv_rotate)
14 print(uv_data[0])
GetVideoVolume ( self, strMeshName, strMaterialName, eChannel )
Get the video volume for all the video channels of the material.
See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData
Parameters
Returns
video volume - float
 9 # Get video volume
10 texture_channel = RLPy.EMaterialTextureChannel_Bump
11 print(material_component.GetVideoVolume(mesh_name, material_name, texture_channel))
LoadImageToTexture ( self, strMeshName, strMaterialName, eChannel, strImagePath )
Import an image into a material texture channel.
See Also: LoadVideoToTexture
Parameters
strImagePath [IN] Image file path - string
Returns
 9 #Load image to material channel
10 texture_channel = RLPy.EMaterialTextureChannel_Diffuse
11 image_file = "C://diffuse.png"
12 result = material_component.LoadImageToTexture(mesh_name, material_name, texture_channel, image_file)
LoadVideoToTexture ( self, strMeshName, strMaterialName, eChannel, strVideoPath )
Import a video into a material texture channel.
See Also: LoadImageToTexture
Parameters
strVideoPath [IN] Video file path - string
Returns
 9 # Create a key
15 material_component.LoadVideoToTexture(key, mesh_name, material_name, texture_channel, video_file)
RemoveUvDataKey ( self, kKey, strMeshName, strMaterialName, eChannel )
Remove an UV data key from a material texture channel.
See Also: AddUvDataKey
Parameters
Returns
 9 # Create a key
12 # Remove UV data key
13 texture_channel = RLPy.EMaterialTextureChannel_Bump  test other channel
14 material_component.RemoveUvDataKey(key, mesh_name, material_name, texture_channel)
