IC Python API:RLPy RQuaternion
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/13/2020
Detailed Description
This class represents a quaternion in mathematics. Quaternions represetn directions as a single rotation, just as rectangular coordinates represent positions as single vector. RQuaternion also defines some constants that can be used directly:
Constant Description
RQuaternion.IDENTITY 4D zero vector: (0, 0, 0, 1)
RQuaternion.ZERO 4D x unit vector: (0, 0, 0, 0) initialization value
Constructor & Destructor
__init__ ( self )
The constructor. Initialize a new RQuaternion object without initialization.
1 q = RLPy.RQuaternion()
3 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # random values
__init__ ( self, vV )
The constructor. Initialize a new RQuaternion object from a 4D vector.
Parameters
vV [IN] a 4D vector - RVector4
1 v = RLPy.RVector4(1, 2, 3, 4)
2 q = RLPy.RQuaternion(v)
3
4 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # 1.0, 2.0, 3.0, 4.0
__init__ ( self, qQ )
Parameters
qQ [IN] a quaternion - RQuaternion
3 p = RLPy.RQuaternion(q)
4
5 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 1.0, 2.0, 3.0, 4.0
__init__ ( self, kAxis, fAngle )
The constructor. Initialize a new RQuaternion object with Axis-angle. The axis is specified by a 3D vector, and the angle is specified by a float value.
Parameters
kAxis [IN] the rotation axis - RVector3
fAngle [IN] the rotation angle - float
1 v = RLPy.RVector3(0, 0, 1)
2 q = RLPy.RQuaternion(v, math.pi/2)
3
5     # 0.0, 0.0, 0.7071067094802856, 0.7071067690849304
__init__ ( self, kRot )
The constructor. Initialize a new RQuaternion object with a 3x3 rotation matrix.
Parameters
kRot [IN] a 3x3 rotation matrix - RMatrix3
2 m = RLPy.RMatrix3(v, math.pi/2)
3 q = RLPy.RQuaternion(m)
4
5 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w))
6     # 0.0, 0.0, 0.7071067690849304, 0.7071067690849304
Operators
The "equal to" operator.
2 p = q
3 if q == p:                         # True
4     print("equal")
The "not equal to" operator.
See Also: ==
1 a = RLPy.RVector4(1, 2, 3, 4)
2 q = RLPy.RQuaternion(a)
3 b = RLPy.RVector4(2, 2, 3, 4)
4 p = RLPy.RQuaternion(b)
5 if a != b:                         #True
6     print("not equal")
The "less than" operator. Similar to string comparison: Returns True upon the first match that is less than and False if it is greater than. If the current comparison is equal, continue onto the next element. If all elements are equal then return False.
See Also: <=
 1 a = RLPy.RVector4(0, 1, 5, 2)
 2 b = RLPy.RVector4(0, 1, 5, 3)
 3 c = RLPy.RVector4(1, 0, 1, 0)
 4 d = RLPy.RVector4(0, 1, 5, 2)
 5
 6 p = RLPy.RQuaternion(a)
 7 q = RLPy.RQuaternion(b)
 8 r = RLPy.RQuaternion(c)
 9 s = RLPy.RQuaternion(d)
10
11 if p< q:                       #True
12     print('p< q')
13 if q< r:                       #True
14     print('q< r')
15 if p< s:                       #False
16     print('p< s')
The "greater than" operator. Similar to string comparison: Returns True upon the first match that is greater than and False if it is less than. If the current comparison is equal, continue onto the next element. If all elements are equal then return False.
See Also: >=
 5
10
11 if q >p:                       #True
12     print('q >p')
13 if r >q:                       #True
14     print('r >q')
15 if p >s:                       #False
16     print('p >s')
The "less than or equal" operator. Similar to string comparison: Returns True upon the first match that is less than and False if it is greater than. If the current comparison is equal, continue onto the next element. If all elements are equal then return True.
See Also: <
 5
10
11 if p<= q:                       #True
12     print('p<= q')
13 if q<= r:                       #True
14     print('q<= r')
15 if p<= s:                       #True
16     print('p<= s')
The "greater than or equal" operator. Similar to string comparison: Returns True upon the first match that is greater than and False if it is less than. If the current comparison is equal, continue onto the next element. If all elements are equal then return True.
See Also: >
 5
10
11 if q >= p:                       #True
12     print('q >= p')
13 if r >= q:                       #True
14     print('r >= q')
15 if p >= s:                       #True
16     print('p >= s')
The "addition" operator. Perform quaternion addition.
See Also: +=
1 a = RLPy.RVector4(0, 1, 2, 3)
2 b = RLPy.RVector4(1, 2, 3, 4)
3 p = RLPy.RQuaternion(a)
4 q = RLPy.RQuaternion(b)
5 r = p + q
6
7 print(str(r.x) + ', ' + str(r.y) + ', ' + str(r.z) + ', ' + str(r.w))  # 1.0, 3.0, 5.0, 7.0
The "subtraction" operator. Perform quaternion subtraction.
See Also: -=
2 b = RLPy.RVector4(3, 2, 1, 0)
5 r = q - p
6
7 print(str(r.x) + ', ' + str(r.y) + ', ' + str(r.z) + ', ' + str(r.w)) # 3.0, 1.0, -1.0, -3.0
The "multiplication" operator. Perform a scalar multiplication when the second operand is an integer or float. If the second operand is another quaternion, then the respective elements are multiplied.
See Also: *=
2 p = RLPy.RQuaternion(a)
3 q = p * 2
4 r = p * p
5
6 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # 2.0, 4.0, 6.0, 8.0
7 print(str(r.x) + ', ' + str(r.y) + ', ' + str(r.z) + ', ' + str(r.w)) # 1.0, 4.0, 9.0, 16.0
The "division" operator. Perform a scalar division with a int or float value which the second operand is limited to.
See Also: /=
3 q = p / 2
4
5 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # 0.5, 1.0, 1.5, 2.0
The "unary minus" operator. Inverse the sign of each element.
3 q = -p
4
5 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # -1.0, -2.0, -3.0, -4.0
The "addition assignment" operator.
5 p += q
6
7 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 1.0, 3.0, 5.0, 7.0
The "subtraction assignment" operator.
1 a = RLPy.RVector4(0, 1, 4, 5)
2 b = RLPy.RVector4(1, 2, 3, 1)
5 p -= q
6
7 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # -1.0, -1.0, 1.0, 4.0
The "multiplication assignment" operator. For calculation method, refer to the * operator.
See Also: *
3 p *= 2
4
5 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 2.0, 4.0, 6.0, 8.0
The "division assignment" operator. For calculation method, refer to the / operator.
See Also: /
3 p /= 2
4
5 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 0.5, 1.0, 1.5, 2.0
Member Functions
AlmostEqual ( self, qQ )
Determine if two quaternions are almost the same within a tolerance of 0.00001.
Parameters
qQ [IN] The target quaternion to check for equivalence - RQuaternion
Returns
True if the two quaternions are almost the same, else False - bool
 3 q = RLPy.RQuaternion(a)
 4 r = RLPy.RQuaternion(a)
 5
 6 q.w = 4.000000001
 7 r.w = 4.00001
 8
 9 if p.AlmostEqual(q):               #True
10     print("p ≈ q")
11 if q.AlmostEqual(r):               #False
12     print("p ≈ r")
Conjugate ( self )
Get the conjugate of this quaternion. The result is a quaternion whose x, y, and z values have been negated.
Returns
The conjugated quaternion. - RQuaternion
3 q = p.Conjugate()
4
5 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # -1.0, -2.0, -3.0, 4.0
Dot ( self, qQ )
Calculate the dot product of two quaternions.
Parameters
qQ [IN] The quaternion to compute dot product - RQuaternion
Returns
Value of the dot product - float
2 b = RLPy.RVector4(1, 2, 3, 0)
5 f = p.Dot(q)
6
7 print(f)     # 14.0
FromAxisAngle ( self, rkAxis, fAngle )
Create a quaternion from axis angle.
Parameters
rkAxis [IN] axis vector - RVector3
fAngle [IN] angle in radians - float
Returns
Return a new quaternion from a axis angle - RQuaternion
1 p = RLPy.RQuaternion()
2 v = RLPy.RVector3(0, 0, 1)
3 p.FromAxisAngle(v, math.pi/2)
4
5 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 0.0, 0.0, 0.7071067094802856, 0.7071067690849304
FromRotationMatrix ( self, rkRot )
Create a quaternion from a rotation matrix.
Parameters
rkRot [IN] Rotation matrix - RMatrix3
Returns
Return a new quaternion from a rotation matrix - RQuaternion
3 p = RLPy.RQuaternion()
4 p.FromRotationMatrix(m)
5
6 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 0.0, 0.0, 0.7071067690849304, 0.7071067690849304
Inverse ( self, rkRot )
Get the inverse of this quaternion.
Returns
The inversed quaternion - RQuaternion
1 a = RLPy.RVector4(1, 1, 1, 1)
3 q = p.Inverse()
4
5 print(str(q.x) + ', ' + str(q.y) + ', ' + str(q.z) + ', ' + str(q.w)) # -0.25, -0.25, -0.25, 0.25
Multiply ( self, qQ )
Multiply this quaternion by another quaternion.
Parameters
qQ [IN] The quaternion to multiply - RQuaternion
Returns
Returns the multiplied quaternion - RQuaternion
2 b = RLPy.RVector4(1, 2, 2, 1)
3
4 p = RLPy.RQuaternion(a)
5 q = RLPy.RQuaternion(b)
6 r = p.Multiply(q)
7
8 print(str(r.x) + ', ' + str(r.y) + ', ' + str(r.z) + ', ' + str(r.w)) # 3.0, 11.0, 11.0, -7.0
MultiplyEqual ( self, qQ )
Parameters
Returns
3
6 r = p.MultiplyEqual(q)
7
Normalize ( self )
Normalize this quaternion, e.g. with a magnitude of 2.
Returns
The normalized quaternion - RQuaternion
3 q = p.Normalize()
4
6     # 0.4999999701976776, 0.4999999701976776, 0.4999999701976776, 0.4999999701976776
Rotate180 ( self )
Rotate this quaternion by 180 degrees.
Returns
The rotated quaternion - RQuaternion
3 q = p.Normalize()
4
6    #0.4999999701976776, 0.4999999701976776, 0.4999999701976776, 0.4999999701976776
SetX ( self, tX )
Set the value of the x-axis.
Parameters
tX [IN] the value of the x-axis - float
3 p.SetX(9)
4
5 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w)) # 9.0, 2.0, 3.0, 4.0
SetY ( self, tY )
Set the value of the y-axis.
Parameters
tY [IN] the value of the y-axis - float
3 p.SetY(9)
4 print(str(p.x) + ', ' + str(p.y) + ', ' + str(p.z) + ', ' + str(p.w))
5     #1.0, 9.0, 3.0, 4.0
SetZ ( self, tZ )
Set the value of the z-axis.
Parameters
tZ [IN] the value of the z-axis - float
3 p.SetZ(9)
5     #1.0, 2.0, 9.0, 4.0
SetW ( self, tW )
Set the value of the w-axis.
Parameters
tW [IN] the value of the w-axis - float
3 p.SetW(9)
5     #1.0, 2.0, 3.0, 9.0
