IC8 Python API:RLPy REventCallback
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 01/17/2023
Description
This class provides a way to monitor iClone events and register callbacks for system events. Once an instance is created, iClone trigger events can be recieved, i.e. playback status, file read status, object creation and deletion status, etc. REventCallback can not be created as a local variable, otherwise the application will crash. Errors in the callback function can also cause the application to crash without warning, therefore, one should consider using Python's try except for fool-proof implementation.
Class Methods
RLPy.REventCallback.OnAfterFileLoaded(self, nFileType)
Callback after the file is loadeded.
Parameters
nFileType[IN] file type - int
 1 class REventCallbackSampleCode(RLPy.REventCallback):
 2     def __init__(self):
 3         RLPy.REventCallback.__init__(self)
 4     def OnAfterFileLoaded(self, nFileType):
 5         print('File type:' + str(nFileType))
 6
 7 event_callback = None
 8
 9 def run_script():
10     global event_callback
11     event_callback = REventCallbackSampleCode()
12     id = RLPy.REventHandler.RegisterCallback(event_callback)
RLPy.REventCallback.OnAfterFileLoadedWithPath(self, nFileType, strFilePath)
Callback before the file is loaded.
Parameters
pProjectName[IN] project name
1 # No example
RLPy.REventCallback.OnAPInitialized(self)
Callback after initialized main AP.
Experimental API
1 # No example
RLPy.REventCallback.OnBeforeLoadFile(self, nFileType)
Callback for before load file.
Parameters
 4     def OnBeforeLoadFile(self, nFileType):
 6
 8
 9 def run_script():
RLPy.REventCallback.OnBeforeLoadFileWithPath(self, nFileType, strFilePath)
Parameters
1 # No example
RLPy.REventCallback.OnBeforeSaveFile(self, nFileType, pProjectName)
Callback for before save file.
Parameters
pProjectName[IN] project name - string
 4     def OnBeforeSaveFile(self, nFileType, strProjectName):
 5         print('File type:' + str(nFileType) + ', Project Name:' + str(pProjectName))
 6
 8
 9 def run_script():
RLPy.REventCallback.OnCurrentTimeChanged(self, fTime)
Callback for current time changed.
Parameters
fTime[IN] current time - float
 4     def OnCurrentTimeChanged (self, fTime):
 5         print('Current time:' + str(fTime))
 6
 8
 9 def run_script():
RLPy.REventCallback.OnDialogModeChanged(self, nDialogMode)
Callback for dialog mode changed.
Parameters
nDialogMode[IN] dialog mode - int
 4     def OnDialogModeChanged(self, nDialogMode):
 5         print('Dialog Mode Changed ~ ' + 'Dialog Mode:' + str(nDialogMode))
 6
 8
 9 def run_script():
RLPy.REventCallback.OnFileLoaded(self, nFileType)
Callback for file loaded.
Parameters
 4     def OnFileLoaded(self, nFileType):
 6
 8
 9 def run_script():
RLPy.REventCallback.OnFileLoadedWithPath(self, nFileType, strFilePath)
Parameters
1 # No example
RLPy.REventCallback.OnFileSaved(self, nFileType, pProjectName)
Callback for file saved.
Parameters
1 # No example
RLPy.REventCallback.OnHierarchyChanged(self)
Callback for hierarchy changed.
Experimental API
 4     def OnHierarchyChanged(self):
 5         print('Hierarchy Changed')
 6
 8
 9 def run_script():
RLPy.REventCallback.OnObjectDataChangedWithType(self, nObjectChangeDataType)
Callback for object data changed with type.
Experimental API
Parameters
nObjectChangeDataType[IN] object change data type - int
 4     def OnObjectDataChangedWithType(self, nDataType):
 5         print('Object Data Changed:' + str(nDataType))
 6
 8
 9 def run_script():
RLPy.REventCallback.OnOmniLiveChanged(self, bOn)
Callback after omni live session status changed.
Experimental API
1 # No example
RLPy.REventCallback.OnProjectDataChanged(self, nProjectDataType)
Callback for project data changed.
Parameters
nProjectDataType[IN] project data type - int
 4     def OnProjectDataChanged(self, nProjectDataType):
 5         print('Project Data type:' + str(nProjectDataType))
 6
 8
 9 def run_script():
RLPy.REventCallback.OnSmartGalleryInitialized(self, bSuccess)
Callback after initialized Smart Gallery.
Experimental API
1 # No example
RLPy.REventCallback.OnTimerUpdated(self, fTime)
Callback for timer updated.
Parameters
 4     def OnTimerUpdated (self, fTime):
 5         print('Updated time:' + str(fTime))
 6
 8
 9 def run_script():
