IC8 Python API:RLPy RFileIO
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 12/27/2022
Description
This class has file load and save capabilities. Currently, you can load iClone-related files, objects, Alembic files, and output FBX files.
Alembic is an interchangeable computer graphics file format developed by Sony Pictures Imageworks and Industrial Light & Magic. Its primary focus is the interchange of geometry (models) between different groups working on the same shots or same assets. In layman's terms, Alembic is an open-source 3D model exchange format that can save animations baked into the geometry.
Supported Files Types
iClone can load the following file formats using LoadFile (highlights in yellow also support LoadObject):
Avatar iavatar iacc ihair iupper ilower ishoe iglove iskin
icloth iteeth aml
Head iface ieye ioral rlhead
Props iprop itree iparticle ipkfx iTerrain iwater isky
Animation imotion imotionplus rlmotion ihand italk rltalk ipath
Scene iimglayer iscene iatm ifog icam ilight ieffect imtl
imtlplus isubstance sbsar itol iscript lua cclightroom
Image jpg jpeg bmp gif png hdr exr tga
Audio mp3 wma m4a aac wav
Video avi mv mpeg mpg mpe mp4 mkv rm
rmvb asf asx wm mov flv
iSprite popvideo iwidget
Physics Constraint iconstraint
Advertise Thumbnail rladv
Model abc obj fbx
Static Methods
RLPy.RFileIO.CheckExportFbxHasLicense(spObject)
Check if the exported FBX has a sell and export license.
Internal use Experimental API
Parameters
spObject[IN] target object - RLPy.RIObject
Returns
RLPy.RStatus.Success - Success
RLPy.RStatus.Failure - Fail
1 # No example
RLPy.RFileIO.ExportFbxFile(args)
Export the FBX file from a scene object by settings.
Experimental API
Parameters
strFilePath[IN] file path - string
kSetting[IN] export fbx settings - RLPy.RExportFbxSetting
Returns
 1 # export fbx for Unreal
 3 export_option = RLPy.EExportFbxOptions__None
 4 export_option2 = RLPy.EExportFbxOptions2__None
 5 export_option3 = RLPy.EExportFbxOptions3__None
 6 export_option = export_option | RLPy.EExportFbxOptions_AutoSkinRigidMesh
 7 export_option = export_option | RLPy.EExportFbxOptions_ExportRootMotion
 8 export_option = export_option | RLPy.EExportFbxOptions_ZeroMotionRoot
 9 export_option = export_option | RLPy.EExportFbxOptions_ExportPbrTextureAsImageInFormatDirectory
10 export_option = export_option | RLPy.EExportFbxOptions_InverseNormalY
11 export_option2 = export_option2 | RLPy.EExportFbxOptions2_UnrealEngine4BoneAxis
12 export_option2 = export_option2 | RLPy.EExportFbxOptions2_RenameDuplicateBoneName
13 export_option2 = export_option2 | RLPy.EExportFbxOptions2_RenameDuplicateMaterialName
14 export_option2 = export_option2 | RLPy.EExportFbxOptions2_RenameTransparencyWithPostFix
15 export_option2 = export_option2 | RLPy.EExportFbxOptions2_RenameBoneRootToGameType
16 export_option2 = export_option2 | RLPy.EExportFbxOptions2_RenameBoneToLowerCase
17 export_option2 = export_option2 | RLPy.EExportFbxOptions2_ResetBoneScale
18 export_option2 = export_option2 | RLPy.EExportFbxOptions2_ResetSelfillumination
19 export_option2 = export_option2 | RLPy.EExportFbxOptions2_ExtraWordForUnityAndUnreal
20 export_option2 = export_option2 | RLPy.EExportFbxOptions2_BakeMouthOpenMotionToMesh
21 export_option2 = export_option2 | RLPy.EExportFbxOptions2_UnrealIkBone
22 export_option2 = export_option2 | RLPy.EExportFbxOptions2_UnrealPreset
23
24 original_size = RLPy.EExportTextureSize_Original
25 default_format = RLPy.EExportTextureFormat_Default
26 include_motion_path = "C://Tpose.rlmotion"
27 result = RLPy.RFileIO.ExportFbxFile( avatar, "C://FBX//avatar.fbx", export_option, export_option2, export_option3, original_size, default_format, include_motion_path )
RLPy.RFileIO.ExportGlbFile(args)
Experimental API
Parameters
kSetting[IN] export fbx settings - RLPy.RExportGlbSetting
sGlbExportOption[IN] export glb options
Returns
1 # No example
RLPy.RFileIO.ExportObjFile(spObject, strFilePath, eOption)
Export the OBJ file from a scene object.
Only Character Creator 3 can use this API. Experimental API
Parameters
eOptions[IN] export options
Returns
1 # No example
RLPy.RFileIO.ExportUsdFile(strFilePath, strPrimeName, eMaterialType, eIncludeMotionType, ePostEffect, sUsdExportOption)
brief Export the USD file from a scene object by settings.
Experimental API
Parameters
strPrimeName[IN] prime name - string
eMaterialType[IN] material type - RLPy.EMaterialType
  • RLPy.EMaterialType_RTX_Real_Time
  • RLPy.EMaterialType_RTX_Path_Traced
eIncludeMotionType[IN] type of include motion - RLPy.EIncludeMotionType
  • RLPy.EIncludeMotionType_Current_Pose
  • RLPy.EIncludeMotionType_Current_Animation
  • RLPy.EIncludeMotionType_Custom
ePostEffect[IN] post effect - RLPy.EPostEffect
  • RLPy.EPostEffect_None
  • RLPy.EPostEffect_Default
  • RLPy.EPostEffect_Faded
  • RLPy.EPostEffect_Cold_Weak
  • RLPy.EPostEffect_Cold_Strong
  • RLPy.EPostEffect_Warm_Weak
  • RLPy.EPostEffect_Warn_Strong
  • RLPy.EPostEffect_Aged
  • RLPy.EPostEffect_Retro
  • RLPy.EPostEffect_Corrupted_purple
  • RLPy.EPostEffect_Black_And_White
sUsdExportOption[IN] export usd options - RLPy.RSUsdExportOption
Returns
1 # No example
RLPy.RFileIO.LoadAlembicFile(spObject, strFilePath, eUpAxis)
Import the alembic file from the given file into the current scene.
Experimental API
Parameters
eUpAxis[IN] coordinate axis - RLPy.ECoordinateAxis
  • RLPy.ECoordinateAxis_X
  • RLPy.ECoordinateAxis_NegativeX
  • RLPy.ECoordinateAxis_Y
  • RLPy.ECoordinateAxis_NegativeY
  • RLPy.ECoordinateAxis_Z
  • RLPy.ECoordinateAxis_NegativeZ
Returns
1 file_path = "C:/test.abc"
2 selection_list = RLPy.RScene.GetSelectedObjects()
3 result = RLPy.RFileIO.LoadAlembicFile(selection_list[0], file_path, RLPy.ECoordinateAxis_Y)
RLPy.RFileIO.LoadFbxFile(args)
Import the scene elements from the given fbx file into the current scene.
Currently supported file types: fbx format.
Parameters
eFbxOption[IN] type of import fbx - RLPy.EImportFbxOption::None
strFbxKeyFilePath[IN] fbxkey file path - string
strNudeTemplateFilePath[IN] "Nude template for glove and shoe" path - string
bRecordStep[IN] Determines whether the current operation steps are to be recorded. If this operation is recorded, it will be included in the program's Undo / Redo management. The default is True - bool
Returns
1 # No example
RLPy.RFileIO.LoadFile(strFilePath, bRecordStep = True)
Import the scene elements from the given file into the current scene.
Currently supported file types: All iClone supported file format.
Parameters
Returns
1 file_path = "c:/myProject.iProject"
2 result = RLPy.RFileIO.LoadFile(file_path)
RLPy.RFileIO.LoadMotion(strFilePath, kTime, spObject)
Load a motion clip into a character or prop.
If you have used PreLoadMotion to load this motion clip, it will not be loaded repeatedly, and the motion clip will be directly mounted.
Parameters
kTime[IN] clip start time - RLPy.RLTime
Returns
1 # No example
RLPy.RFileIO.LoadObject(strFilePath, bRecordStep = True)
Experimental API
Parameters
Returns
RIObjectPtrThe requested object returned as a Type.
1 object = RLPy.RFileIO.LoadObject("C:/CC_Standard_Neutral.iavatar")
2 print(type(object)) #RLPy.RIAvatar
3
4 object = RLPy.RFileIO.LoadObject("C:/Arc_001.iProp")
5 print(type(object)) #RLPy.RIProp
RLPy.RFileIO.LoadSubstancePainterTextures(spObject, strFolderPath)
Load textures from Substance Painter.
Only supports character. Experimental API
Parameters
strFolderPath[IN] folder path - string
Returns
1 # No example
RLPy.RFileIO.PreLoadMotion(strFilePath, spObject, kMotionLength)
Pre-load motion clips to characters or props.
When you really need to mount them to characters or props, please call LoadMotion.
Parameters
Returns
1 # No example
RLPy.RFileIO.SaveFile(spObject, kSaveSetting, strSavePath)
brief Save file from a scene object by settings.
Experimental API
Parameters
kSaveSetting[IN] save file settings - RLPy.RSaveFileSetting
Returns
1 # No example
RLPy.RFileIO.SaveProject(strSavePath)
brief Save the current scene as a new project.
Experimental API
Parameters
Returns
1 # No example
RLPy.RFileIO.SaveThumbnailToFile(strRLFile, strSaveTo)
Save thumbnails of RL files as an image file.
Parameters
strRLFile[IN] RL file path - string
strSaveTo[IN] Saved thumbnail path - string
Returns
1 # No example
