IC8 Python API:RLPy RIClip
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 01/9/2023
Description
An animation clip representes a sequence of connected motions. Different types of animations can be derived from composing clips and applying various clip operations. Animation clips are recorded for each character bone node or a scene object itself. One can access an animation clip's transform control via RIClip, to facilitate subsequent key operations.
Animation keys reside in clips:
Class Methods
RLPy.RIClip.ClipTimeToSceneTime(self, kClipTick)
Convert clip time to Scene time.
Parameters
kClipTime[IN] clip time.
Returns
Scene time - RLPy.RLTime
 1 # Get skeleton component
 2 avatar_list = RLPy.RScene.GetAvatars()
 3 avatar = avatar_list[0]
 4 bone = avatar.GetSkeletonComponent()
 5
 6 # Clip time to scene time
 7 clip_index = 1
 8 clip = bone.GetClip(clip_index)
 9 clip_time = RLPy.RTime(2000)
10 scene_time = clip.ClipTimeToSceneTime(clip_time)
RLPy.RIClip.GetClipLength(self)
Get length of the clip.
Affected by whether there is loop and adjusting speed.)
Returns
clip length - RLPy.RLTime
1 # No example
RLPy.RIClip.GetControl(self, strKey, spNode)
Get transform control of the bone node.
Parameters
strKey[IN] Key of the controller, allowing use "Layer" as the key to retrieve the control of the Motion Layer in the clip - string
spNode[IN] Specifies the corresponding node to get the control - RLPy.RIBase
Returns
Return the controller of the specified key. It will return null while not found or the key is invalid - RLPy.RControl
5
6 # Get transform control from bone root
7 clip_index = 1
9 transform_control = clip.GetControl("Layer", bone.GetRootBone())
RLPy.RIClip.GetDataBlock(self, strKey, spBase)
Get DataBlock of specify data.
Parameters
strKey[IN] Key of the controller, allowing use "Layer" as the key to retrieve the data block of the layer keys in the clip - string
spBase[IN] Specifies the corresponding object to get the data block - RLPy.RIBase
Returns
Return the data block of the specified key. It will return null while not found or the key is invalid - RLPy.RDataBlock
1 # No example
RLPy.RIClip.GetEffectorDataBlock(self, strKey, spBase, spDataBlock, spActiveDataBlock)
Get DataBlock of effector.
Parameters
spBase[IN] Specifies the corresponding object to get the effector data block - RLPy.RIBase
spDataBlock[OUT] the translattion/rotation data block of effector - RLPy.RDataBlock spActiveDataBlock[OUT] the active data block of effector - RLPy.RDataBlock
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 # No example
RLPy.RIClip.GetLastKeyTime(self)
Get time of the last key in the clip.
Returns
time of the last key in the clip - RLPy.RLTime
5
6 # Get last key time
7 clip_index = 1
9 last_key_time = clip.GetLastKeyTime()
RLPy.RIClip.GetLength(self)
Returns
5
6 # Get clip length
7 clip_index = 1
9 clip_len = clip.GetLength()
RLPy.RIClip.GetLoopCount(self)
get the loop count of the clip
Returns
loop count - float
1 # No example
RLPy.RIClip.GetSpeed(self)
get the speed of the clip
Returns
clip speed - float
1 # No example
RLPy.RIClip.GetTransitionData(self)
Get transition data of the clip.
Returns
list of the transition time [fade-in start, fade-in end, fade-out start, fade- out end] - list
1 # No example
RLPy.RIClip.GetTransitionRange(self)
Get fade-in transition time.
Returns
transition time - RLPy.RLTime
1 # No example
RLPy.RIClip.GetTransitionStrength(self, bFadeIn)
Get transition strength of the clip.
Parameters
bFadeIn[IN] true: fade-in, false: fade-out - bool
Returns
Transition strength of the clip (0~100) - float
1 # No example
RLPy.RIClip.GetTransitionType(self, bFadeIn)
Get transition type of the clip.
Parameters
Returns
Transition type of the clip - RLPy.ETransitionType
  • RLPy.ETransitionType_Invalid Invalid value.
  • RLPy.ETransitionType_None None.
  • RLPy.ETransitionType_Linear Linear.
  • RLPy.ETransitionType_Step Step.
  • RLPy.ETransitionType_Ease_Out Ease out.
  • RLPy.ETransitionType_Ease_In Ease in.
  • RLPy.ETransitionType_Ease_Out_In Ease out in.
  • RLPy.ETransitionType_Ease_In_Out Ease in out.
  • RLPy.ETransitionType_Ease_In_Sine Ease in sine.
  • RLPy.ETransitionType_Ease_Out_Sine Ease out sine.
  • RLPy.ETransitionType_Ease_In_Out_Sine Ease in out sine.
  • RLPy.ETransitionType_Ease_In_Quad Ease in quad.
  • RLPy.ETransitionType_Ease_Out_Quad Ease out quad.
  • RLPy.ETransitionType_Ease_In_Out_Quad Ease in out quad.
  • RLPy.ETransitionType_Ease_In_Cubic Ease in cubic.
  • RLPy.ETransitionType_Ease_Out_Cubic Ease in out cubic.
  • RLPy.ETransitionType_Ease_In_Out_Cubic Ease in out cubic.
  • RLPy.ETransitionType_Ease_In_Quart Ease in quart.
  • RLPy.ETransitionType_Ease_Out_Quart Ease out quart.
  • RLPy.ETransitionType_Ease_In_Out_Quart Ease in out quart.
  • RLPy.ETransitionType_Ease_In_Quint Ease in quint.
  • RLPy.ETransitionType_Ease_Out_Quint Ease out quint.
  • RLPy.ETransitionType_Ease_In_Out_Quint Ease in out quint.
  • RLPy.ETransitionType_Ease_In_Expo Ease in expo.
  • RLPy.ETransitionType_Ease_Out_Expo Ease out expo.
  • RLPy.ETransitionType_Ease_In_Out_Expo Ease in out expo.
  • RLPy.ETransitionType_Ease_In_Circ Ease in circ.
  • RLPy.ETransitionType_Ease_Out_Circ Ease out circ.
  • RLPy.ETransitionType_Ease_In_Out_Circ Ease in out circ.
  • RLPy.ETransitionType_Ease_In_Back Ease in back.
  • RLPy.ETransitionType_Ease_Out_Back Ease out back.
  • RLPy.ETransitionType_Ease_In_Out_Back Ease in out back.
  • RLPy.ETransitionType_Ease_In_Elastic Ease in elastic.
  • RLPy.ETransitionType_Ease_Out_Elastic Ease out elastic.
  • RLPy.ETransitionType_Ease_In_Out_Elastic Ease in out elastic.
  • RLPy.ETransitionType_Ease_In_Bounce Ease in bounce.
  • RLPy.ETransitionType_Ease_Out_Bounce Ease out bounce.
  • RLPy.ETransitionType_Ease_In_Out_Bounce Ease in out bounce.
  • RLPy.ETransitionType_Last Last.
  • RLPy.ETransitionType_Count
1 # No example
RLPy.RIClip.GetType(self)
Get type of the clip.
Returns
clip type - int
1 # No example
RLPy.RIClip.SceneTimeToClipTime(self, kSceneTick)
Convert Scene time to clip time.
Parameters
kSceneTime[IN] Scene time.
Returns
clip time - RLPy.RLTime
 5
 6 # Scene time to clip time
 7 clip_index = 1
 9 scene_time = RLPy.RTime(13000)
10 clip_time = clip.SceneTimeToClipTime(scene_time)
RLPy.RIClip.SetLength(self, kLength)
Set length of the clip.
Parameters
kLength[IN] clip length - RLPy.RLTime
Returns
 5
 6 # Set clip length
 7 clip_index = 1
 9 clip_len = RLPy.RTime(2000)
10 clip.SetLength(clip_len)
RLPy.RIClip.SetSpeed(self, fSpeed)
set the speed of the clip
Parameters
fSpeed[IN] speed of the clip - float
Returns
1 # No example
RLPy.RIClip.SetTransitionData(self, kData)
Modify the transition time.
Returns
kData [IN] list of the transition time [fade-in start, fade-in end, fade-out start, fade-out end] - RLPy.RStatus
Returns
1 # No example
RLPy.RIClip.SetTransitionRange(self, kLength)
Modify the fade-in transition time.
Parameters
kLength[IN] length of transition time - RLPy.RLTime
Returns
1 # No example
RLPy.RIClip.SetTransitionType(self, bFadeIn, eTransitionType, fTransitionStrength)
Set transition type of the clip.
Parameters
eTransitionType[IN] Transition type of the clip - RLPy.ETransitionType
fTransitionStrength[IN] Transition strength of the clip (0~100) - float
Returns
1 # No example
