IC8 Python API:RLPy RIPhysicsComponent
From Reallusion Wiki!
Jump to: navigation, search
Contents
Main article: iC8 Modules.
Last modified: 02/19/2023
Description
Missing description.
Class Methods
RLPy.RIPhysicsComponent.GetSoftPhysicsMaterialNameList(self, strMeshName )
Get all material names which are available to modify weight map.
Experimental API
Returns
std::vector<std::wstring > material names
1 # No example
RLPy.RIPhysicsComponent.GetSoftPhysicsMeshNameList(self)
Get all mesh names which are available to modify weight map.
Experimental API
Returns
std::vector<std::wstring > mesh names
1 # No example
RLPy.RIPhysicsComponent.GetSoftPhysXCollisionEnable(self, strMeshName, strMaterialName, strCollisionName )
Get status of PhysX checkboxs.
Experimental API
Parameters
strMeshName[IN] The name for mesh - string
strMaterialName[IN] The name for material of mesh - string
strPropertyName[IN] The name for material's PhysX collision.
Returns
enable(true) or disable (false)
1 # No example
RLPy.RIPhysicsComponent.GetSoftPhysXCollisionValue(self, strMeshName, strMaterialName, strCollisionName )
Experimental API
Parameters
Returns
valueof PhysX collision
1 # No example
RLPy.RIPhysicsComponent.GetSoftPhysXProperty(self, strMeshName, strMaterialName, strPropertyName )
Experimental API
Parameters
strPropertyName[IN] The name for material's PhysX property - string
Returns
valueof PhysX property
1 # No example
RLPy.RIPhysicsComponent.IsActivatePhysicsEnable(self)
Experimental API
Returns
1 # No example
RLPy.RIPhysicsComponent.IsObjectGravityEnable(self, strMeshName, strMaterialName )
Experimental API
Parameters
strMeshName[IN] The name for material - string
Returns
1 # No example
RLPy.RIPhysicsComponent.SavePhysicsSoftColthWeightMap(self, strMeshName, strMaterialName, strFilePath )
Get matherial weight image.
Experimental API
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 # No example
RLPy.RIPhysicsComponent.SetActivatePhysicsEnable(self, bActivate )
Set status of PhysX checkboxs.
Experimental API
Parameters
bCheck[IN] The status of checkbox.
Returns
1 # No example
RLPy.RIPhysicsComponent.SetObjectGravityEnable(self, strMeshName, strMaterialName, bObjectGravity )
Experimental API
Parameters
Returns
1 # No example
RLPy.RIPhysicsComponent.SetPhysicsSoftColthWeightMap(self, strMeshName, strMaterialName, strFilePath )
Set matherial weight image.
Experimental API
Returns
1 # No example
RLPy.RIPhysicsComponent.SetSoftPhysXCollisionEnable(self, strMeshName, strMaterialName, strCollisionName, bEnable )
Experimental API
Parameters
strCheckboxName[IN] The name for material's PhysX collision.
fPropertyName[IN] The value of PhysX collision.
Returns
1 # No example
RLPy.RIPhysicsComponent.SetSoftPhysXCollisionValue(self, strMeshName, strMaterialName, strCollisionName, fValue )
Experimental API
Parameters
Returns
1 # No example
RLPy.RIPhysicsComponent.SetSoftPhysXProperty(self, strMeshName, strMaterialName, strPropertyName, fValue )
Experimental API
Parameters
strCheckboxName[IN] The name for material's PhysX property.
fPropertyName[IN] The value of PhysX property.
Returns
1 # No example
