IC8 Python API:RLPy RIPopcornFXObject
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 02/19/2023
Description
This class is the interface to PopcornFX object in the scene. It provides methods to access various parts of a PopcornFX object such as emit, loop, transformation, etc. All methods of this class are implemented internally.
Class Methods
RLPy.RIPopcornFXObject.AddAttributeKey(self, strName, kTime, kValue )
Add an attribute key to this PopcornFX object.
Experimental API
Parameters
kTime[IN] The time at which to add the key - RLPy.RLTime
kValue[IN] The value of the attribute must have four floating point numbers. The maximum and minimum values of each attribute are different - float
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 popcorn = RLPy.RScene.FindObject( RLPy.EObjectType_PopcornFX, "Trail Emitter" )
2 #Add attribute key
3 key_time = RLPy.RTime(67)
4 new_attr_value = (2,0,0,0) # must have four floating point numbers.
5 popcorn.AddAttributeKey(attr_name, key_time, new_attr_value)
RLPy.RIPopcornFXObject.ClearMeshSamplerTarget(self, strSamplerName )
Clear target object of Mesh Sample by name.
Experimental API
Parameters
strSamplerName[IN] sampler name - string
Returns
 2 #Clear mesh sampler target
 3 mesh_sampler_names = popcorn.GetSamplerList(RLPy.EPopcornFxSamplerType_MESH)
 4 if len(mesh_sampler_names) > 0:
 5     sampler_name = mesh_sampler_names[0]
 6     prop = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box")
 7     ret = popcorn.SetMeshSamplerTarget(sampler_name, prop)
 8     if ret == RLPy.RStatus.Success:
 9         target = popcorn.GetMeshSamplerTarget(sampler_name)
10         if target != None:
11             print(target.GetID() == prop.GetID())  #True
12         ret = popcorn.ClearMeshSamplerTarget(sampler_name)
13         print(ret is RLPy.RStatus.Success)  #True
RLPy.RIPopcornFXObject.GetAttributeCount(self)
Get the number of all attributes of this Popcorn object.
Experimental API
Returns
Returns the number of attributes - int
2 #Get attribute count
3 attr_qty = popcorn.GetAttributeCount()
4 print(attr_qty)
RLPy.RIPopcornFXObject.GetAttributeName(self, nIndex )
Get attribute names by index.
Experimental API
Parameters
nIndex[IN] attribute index - int
Returns
Returns the attribute name - string
2 #Get the name of the 2nd attribute
3 attr_name = popcorn.GetAttributeName(2)
4 print(attr_name) #alignMode
RLPy.RIPopcornFXObject.GetAttributeValue(self, nIndex )
Get attribute value by index.
Experimental API
Parameters
Returns
Returns the attribute value - float
2 #Get the value for the 3rd attribute
3 attr_value = popcorn.GetAttributeValue(3)
4 print(attr_value) #(0,0,0,0)
RLPy.RIPopcornFXObject.GetEmit(self)
Get current emit state of the particle.
Experimental API
Returns
Returns the emit on/off state - bool
2 print(popcorn.GetEmit())
RLPy.RIPopcornFXObject.GetEmitKeyCount(self)
Get the current number of emit keys.
Experimental API
Returns
Return keys count - int
1 # No example
RLPy.RIPopcornFXObject.GetLoopInterval(self)
Get the current popcorn object how many seconds per loop will be emit once.
Experimental API
Returns
Returns emission interval - float
2 #Get loop interval
3 print(popcorn.GetLoopInterval()) #5
RLPy.RIPopcornFXObject.GetMeshSamplerTarget(self, strSamplerName )
Get target of Mesh Sampler by name.
Experimental API
Parameters
Returns
Return sampler target object - RLPy.RIObject
2 #Get sampler target
RLPy.RIPopcornFXObject.GetSamplerList(self, eType )
Get the Sampler list of this object based on the type.
Experimental API
Parameters
eType[IN] sampler type - RLPy.EPopcornFxSamplerType
  • RLPy.EPopcornFxSamplerType_MESH
  • RLPy.EPopcornFxSamplerType_IMAGE
  • RLPy.EPopcornFxSamplerType_SOUND
  • RLPy.EPopcornFxSamplerType_TEXT
  • RLPy.EPopcornFxSamplerType_PATH
  • RLPy.EPopcornFxSamplerType_CURVE
Returns
Return all sampler names of this type - string
2 #Get sampler list
RLPy.RIPopcornFXObject.IsLoop(self)
Set this popcorn object to enable loop emit or disable loop mode.
Experimental API
Parameters
bLoop[IN] Loop mode or not.
fEmissionInterval[IN] the number of seconds between each loop.
Returns
2 print(popcorn.IsLoop())
RLPy.RIPopcornFXObject.RemoveEmitKeys(self)
Remove all emit keys of this Popcorn object.
Experimental API
Returns
2 #Remove all emit keys
3 popcorn.RemoveEmitKeys()
RLPy.RIPopcornFXObject.SetEmit(self, kTime, bOn )
Set the emit state of the particle.
Experimental API
Parameters
kTime[IN] Specifies the time to set - RLPy.RLTime
bOn[IN] The emit on/off state - bool
Returns
2 popcorn.SetEmit(RLPy.RTime(100), True)
RLPy.RIPopcornFXObject.SetLoop(self, bLoop )
Experimental API
Parameters
bLoop[IN] Loop mode or not - bool
Returns
2 popcorn.SetLoop(True)
RLPy.RIPopcornFXObject.SetLoopInterval(self, fEmissionInterval )
Set every second interval to emit.
Experimental API
Parameters
fEmissionInterval[IN] the number of seconds between each loop - float
Returns
2 #Set loop interval
3 popcorn.SetLoop(True)
4 popcorn.SetLoopInterval(5)
RLPy.RIPopcornFXObject.SetMeshSamplerTarget(self, strSamplerName, spObject )
Set target object of Mesh Sample by name.
Experimental API
Parameters
spObject[IN] sampler target object - RLPy.RIObject
Returns
2 #Set sampler target
