IC8 Python API:RLPy RIProp
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 02/3/2023
Description
This class can be used to access basic information of prop objects and obtain the control or components of the prop to modify its the transform values and materials.
Class Methods
RLPy.RIProp.GetMaterialComponent(self)
Get material component of the object.
Returns
Pointer of the RIMaterialComponent object - RLPy.RIMaterialComponent
 1 prop = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box")
 2 # get component
 3 material_component = prop.GetMaterialComponent()
 4 mesh_list = prop.GetMeshNames()
 5 mesh_name = mesh_list[0]
 6 material_list = material_component.GetMaterialNames(mesh_name)
 7 material_name = material_list[0]
 8
 9 # Modify material light - ambient channel
10 ambient_color = RLPy.RRgb.RED
11
12 # Create Key
13 key = RLPy.RKey()
14 key.SetTime(RLPy.RTime(1200))
15 key.SetTransitionType(RLPy.ETransitionType_Linear)
16 key.SetTransitionStrength(50)
17 material_component.AddAmbientKey(key, mesh_name, material_name, ambient_color)
18 print(material_component.GetAmbientColor(mesh_name, material_name))
RLPy.RIProp.GetMorphComponent(self)
Get morph component of the object.
Returns
Pointer of the RIMorphComponent object - RLPy.RIMorphComponent
 2 # get component
 3 morph_component = prop.GetMorphComponent()
 4 result = morph_component.AddKey( "your_mesh_name", "your_morph_name", RLPy.RTime(67),  0.5, False, False )
 5
 6 f_ret_weight = 0
 7 return_list = morph_component.GetWeight( "your_mesh_name", "your_morph_name", RLPy.RTime(67), f_ret_weight )
 8 f_ret_weight = return_list[1]
 9 print(f_ret_weight) # is 0.5
10
11 result = morph_component.RemoveAllKeys("your_mesh_name", "your_morph_name")
12 morph_names = morph_component.GetMorphNames("your_mesh_name")
RLPy.RIProp.GetSkeletonComponent(self)
Get bone root of the object.
Returns
bone root - RLPy.RISkeletonComponent
 2 # get component
 3 bone = prop.GetSkeletonComponent()
 4 print(bone.GetClip(0))
 5
 6 # get selected bone
 7 selected_bones = bone.GetSelectedBones()
 8 print(len(selected_bones))
 9
10 # get root bone
11 root_bone = bone.GetRootBone()
12 print(root_bone)
RLPy.RIProp.IsDummy(self)
Check if prop state is dummy.
Experimental API
Returns
Boolvalue true if prop state is dummy; otherwise false.
2 prop.SetDummy( True )
3 is_dummy = prop.IsDummy()
4 print( is_dummy )  #True
RLPy.RIProp.IsVisible(self, kTime )
Check if prop is visible.
Experimental API
Parameters
kTime[IN] Specifies the time to check if prop is visible - RLPy.RLTime
Returns
Boolvalue true if prop is visible; otherwise false.
1 # No example
RLPy.RIProp.SetDummy(self, bIsDummy )
Set the prop state whether its dummy or not.
Experimental API
Parameters
bIsDummy[IN] takes prop state as bool value : true or false - bool
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
RLPy.RIProp.SetPivot(self, kPosition, kOrientation )
This function lets you re-position and re-orient the current object's pivot.
Experimental API
Parameters
kPosition[IN] pivot position - RLPy.RVector3f
kOrientation[IN] pivot orientation - RLPy.RVector3f
Returns
2 #set pivot
3 pos = RLPy.RVector3( 10, 10, 10 )
4 rot = RLPy.RVector3( 0, 0, 0 )
5 ret = prop.SetPivot( pos, rot )
6 print(ret)
RLPy.RIProp.SetVisible(self, kTime, bVisible )
Experimental Function)Set visible status
Parameters
kTime[IN] Specifies the time to set visible - RLPy.RLTime
bVisible[IN] Visible status - bool
Returns
2 ret = prop.SetVisible( RLPy.RTime( 67 ), false )
3 print(ret)
