IC8 Python API:RLPy RIVisemeComponent
From Reallusion Wiki!
Jump to: navigation, search
Contents
Main article: iC8 Modules.
Last modified: 10/21/2026
Description
This class provides viseme related operations including reading an audio source and creating a viseme clip out of it. It can also add and remove keys from the viseme clip as well as provide Text-to-Speech capabilities. A viseme track within the timeline will show viseme clips and mouth shapes (viseme keys). The lip options track also includes the viseme smooth clip which can be used to smooth out the transition between the different mouth shapes in the event of a lip-sync animation.
Viseme keys in the "Lips" track:
Class Methods
RLPy.RIVisemeComponent.AddVisemeKey(self, kKey)
Add a viseme key.
Experimental API
Parameters
kKey[IN] The key to be added - RLPy.RVisemeKey
Returns
Success or Fail or InvalidParameter - RLPy.RStatus
1 # add viseme key to viseme clip
2 expressiveness = 50
3 viseme_key = RLPy.RVisemeKey(RLPy.EVisemeID_AH, expressiveness)
4 viseme_key.SetTime(RLPy.RTime(100))
5 viseme_animator.AddVisemeKey(viseme_key)
RLPy.RIVisemeComponent.AddVisemeOptionClip(self, kSmoothOption, kStartTick, strClipName)
You can separately adjust the viseme animation strength/smooth for the tongue, lips, and jaw from this function.
Parameters
kSmoothOption[IN] Settings of Smooth/Strength - RLPy.RVisemeSmoothOption
kStartTick[IN] Specifies the start Tick of the clip - RLPy.RLTime
strClipName[IN] The name of the clip - string
Returns
1 audio_object = RLPy.RAudio.CreateAudioObject()
2 audio_object.Load("C:\\sample.wav")
3 clip_name = "VisemeClip"
4 clip_start_time = RLPy.RTime(0)
5 viseme_animator.LoadVocal(audio_object, clip_start_time, clip_name)
6 viseme_animator.AddVisemeOptionClip(viseme_smooth_option, clip_start_time, clip_name)
RLPy.RIVisemeComponent.AddVisemesClip(self, kTick, strClipName, kClipLength)
Add a viseme clip.
Experimental API
Parameters
kTick[IN] Setting of clip's begin Tick - RLPy.RLTime
strClipName[IN] Name of the Clip - string
kClipLength[IN] Tick of clip length, the value must be greater than 0 - RLPy.RLTime
Returns
1 clip_name = "VisemeClip"
2 time_begin = RLPy.RTime(0)
3 clip_length = RLPy.RTime(1000)
4 viseme_animator.AddVisemesClip(time_begin, clip_name, clip_length)
RLPy.RIVisemeComponent.AddVisemesClipWithData(self, args)
Add a viseme clip.
Experimental API
Parameters
kTime[IN] Setting of clip's begin time - RLPy.RLTime
pAudio[IN] audio object - RLPy.RIAudioObject
kKeys[IN] the list of viseme key - RLPy.RVisemeKey
kWords[IN] the list of word data - RLPy.RWordData
strText[IN] text of the clip - string
Returns
Success or Fail - RLPy.RStatus
1 # No example
RLPy.RIVisemeComponent.GetClip(self, uIndex)
Get facial clip.
Experimental API
Parameters
uIndex[IN] Index of the clip - int
Returns
Pointer to the clip - RLPy.RIClip
1 # No example
RLPy.RIVisemeComponent.GetClipByTime(self, kHitTime)
Get facial clip.
Experimental API
Parameters
kHitTime[IN] time during clip range - RLPy.RLTime
Returns
1 # No example
RLPy.RIVisemeComponent.GetClipCount(self)
Get number of facial clips.
Experimental API
Returns
Number of facial clips - int
1 # No example
RLPy.RIVisemeComponent.GetStrength(self)
Get the strength of viseme.
Experimental API
Returns
The value of strength - float
1 # Get avatar viseme component
2 avatar_list = RLPy.RScene.GetAvatars()
3 avatar = avatar_list[0]
4 viseme_component = avatar.GetVisemeComponent()
5
6 strength = viseme_component.GetStrength()
RLPy.RIVisemeComponent.GetVisemeBones(self)
Get all viseme bones.
Experimental API
Returns
Pointer to viseme root bone - list
5
6 # Get viseme bones
7 viseme_bones = viseme_component.GetVisemeBones()
RLPy.RIVisemeComponent.GetVisemeKey(self, kTime, kKey)
Get viseme key information.
Experimental API
Parameters
kTick[IN] Tick of the key.
kKey[OUT] viseme key - RLPy.RVisemeKey
Returns
5
6 # Get viseme key
7 ret_key = RLPy.RVisemeKey()
8 result = viseme_component.GetVisemeKey(RLPy.RTime(0), ret_key)
RLPy.RIVisemeComponent.GetVisemeKeys(self)
Get Tick of all viseme keys.
Experimental API
Returns
Tick of the key - list
5
6 # Get viseme keys
7 viseme_key_list = viseme_component.GetVisemeKeys()
RLPy.RIVisemeComponent.GetVisemeMorphWeights(self)
Get all morph weights of viseme.
Experimental API
Returns
The value of morph weights - float
5
6 # Get viseme morph weights
7 viseme_weights = viseme_component .GetVisemeMorphWeights()
RLPy.RIVisemeComponent.GetVisemeNames(self)
Get name list of the visme control.
Experimental API
Returns
name list of the visme control - string
1 # No example
RLPy.RIVisemeComponent.GetWords(self, nClipIndex = -1)
Get word data (acculips).
Experimental API
Parameters
nClipIndex[IN] the index of the clip, if the value is -1, it will return all words - int
Returns
word data - list
1 # No example
RLPy.RIVisemeComponent.LoadVocal(self, args)
Import voice source to generate Lips using AccuLips.
Parameters
pAudio[IN] Input audio source - RLPy.RIAudioObject
strText[IN] Corresponding text with input audio source. If input text is empty, AccuLip will generate it from audio automatically - string
kStartTime[IN] Specifies the start time of the clip - RLPy.RLTime
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
 5
 6 # Load vocal with create audio object
 7 audio = RLPy.RAudio.CreateAudioObject()
 8 audio_path = "./SpecialDay.wav"
 9 start_time = RLPy.RGlobal.GetTime()
10 RLPy.RAudio.LoadAudioToObject(avatar, audio_path, start_time)
11 clip_name = "Default"
12 result = viseme_component.LoadVocal(audio, start_time, clip_name)
13
14 # Load vocal with audio recorder
15 audio_recorder = RLPy.RAudioRecorder()
16 audio_recorder.Start()
17 audio_recorder.Stop()
18 audio_source = audio_recorder.GetAudio()
19 start_time = RLPy.RGlobal.GetTime()
20 clip_name = "Default"
21 result = viseme_component.LoadVocal(audio_source, start_time, clip_name)
RLPy.RIVisemeComponent.RemoveVisemesClip(self, kTick)
Remove viseme clip.
Experimental API
Parameters
kTick[IN] The Tick for finding viseme clip - RLPy.RLTime
Returns
5
6 # Remove a viseme clip at 1000 ms
7 result = viseme_component.RemoveVisemesClip(RLPy.RTime(1000))
RLPy.RIVisemeComponent.RemoveVisemesKey(self, kKey)
Remove viseme key.
Experimental API
Parameters
kKey[IN] Specifies the time to remove key - RLPy.RVisemeKey
Returns
 5
 6 # Remove visemes key
 7 key = RLPy.RVisemeKey()
 8 key.SetTime(RLPy.RTime(300))
 9 key.SetID(RLPy.EVisemeID_AH)
10 key.SetWeight(80)
11 result = viseme_component.RemoveVisemesKey(key)
RLPy.RIVisemeComponent.TextToSpeech(self, args)
set speech from text.
Experimental API
Parameters
strContent[IN] Content of speech - string
eLanguage[IN] Language of speech system - RLPy.ELanguage
  • RLPy.ELanguage_TW
  • RLPy.ELanguage_US
fVolume[IN] Settings of Volume, the range is from 0.0 to 100.0 - float
fPitch[IN] Settings of Pitch, the range is from 0.0 to 100.0 - float
fSpeed[IN] Settings of Speed, the range is from 0.0 to 100.0 - float
Returns
5
6 result = viseme_component.TextToSpeech("speech", RLPy.ELanguage_US, 100, 50, 50)
RLPy.RIVisemeComponent.TextToVisemeData(self, strContent, fVolume = 100., fPitch = 50., fSpeed = 50.)
Get viseme data from text.
Experimental API
Parameters
Returns
Success or Fail or InvalidParameter - int
5
6 result = viseme_component.TextToVisemeData("speech", 100, 50, 50)
Description
This class provides viseme related operations including reading an audio source and creating a viseme clip out of it. It can also add and remove keys from the viseme clip as well as provide Text-to-Speech capabilities. A viseme track within the timeline will show viseme clips and mouth shapes (viseme keys). The lip options track also includes the viseme smooth clip which can be used to smooth out the transition between the different mouth shapes in the event of a lip-sync animation. Viseme keys in the "Lips" track.
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new ri viseme component instance.
Parameters
  • args
  • kwargs
Member Functions
AddVisemeKey (self, kKey)
Add a viseme key inside the current viseme clip. If the strength value of the viseme key lies outside of the range (0-100), or if a viseme clip does not exist then return RLPy.RStatus.Failure. See Also: RemoveVisemesKey
Parameters
  • kKey
AddVisemeOptionClip (self, kSmoothOption, kStartTick, strClipName)
Add a viseme smooth settings clip to the character. If a viseme clip does not exist at the start time, then a viseme smooth clip will not be deployed.
Parameters
  • kSmoothOption
  • kStartTick
  • strClipName
AddVisemesClip (self, kTick, strClipName, kClipLength)
Add an empty viseme clip to the character. See Also: RemoveVisemesClip
Parameters
  • kTick
  • strClipName
  • kClipLength
AddVisemesClipWithData (self, *args)
Adds a viseme clip.
Parameters
  • args
ChangeTalkingStyle (self, pClip, strPresetName)
Change talking style preset.
Parameters
  • pClip
  • strPresetName
GetClip (self, uIndex)
Gets facial clip.
Parameters
  • uIndex
GetClipByTime (self, kHitTime)
Gets facial clip.
Parameters
  • kHitTime
GetClipCount (self)
Gets number of facial clips.
GetStrength (self)
Get the viseme strength value.
GetVisemeBones (self)
Get all of the viseme bone joints on this character.
GetVisemeKey (self, kTime, kKey)
Get the viseme key for the given time. If a viseme clip does not exist then return RLPy.RStatus.Failure. See Also: GetVisemeKeys
Parameters
  • kTime
  • kKey
GetVisemeKeys (self)
Get all the viseme keys inside all of the viseme clips on this character. See Also: GetVisemeKey
GetVisemeMorphWeights (self)
Get all of the viseme morph weights on this character.
GetVisemeNames (self)
Returns the viseme names.
GetWords (self, nClipIndex=-1)
Returns the words.
Parameters
  • nClipIndex (default: -1)
LoadVocal (self, *args)
Create a viseme clip for this character with a given audio source.
Parameters
  • args
RemoveVisemesClip (self, kTick)
Remove a viseme clip on the character at the requested time. If a viseme clip does not exist at the given time then return RLPy.RStatus.Failure. See Also: AddVisemesClip
Parameters
  • kTick
RemoveVisemesKey (self, kKey)
Delete a viseme key within a viseme clip at the given time. If a viseme clip is missing or a viseme key does not exist at the given time, then return RLPy.RStatus.Failure.
Parameters
  • kKey
TextToSpeech (self, *args)
Create a viseme clip from script processed through text-to-speech; See Also: TextToVisemeData
Parameters
  • args
TextToVisemeData (self, strContent, fVolume=100.0, fPitch=50.0, fSpeed=50.0)
When this character is provided a script processed by Text-To-Speech (TTS); Use this function can retrieve all the viseme IDs along with their corresponding times. See Also: TextToSpeech
Parameters
  • strContent
  • fVolume (default: 100.0)
  • fPitch (default: 50.0)
  • fSpeed (default: 50.0)
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
