IC Python API:Message Box
From Reallusion Wiki!
Jump to: navigation, search
Main article: RL Python Samples.
iClone Python API has the ability to display pop-up message boxes that can ease the flow of your scripted procedures, as well as provide warnings and alerts. Message boxes can be sparse with no interaction except for the universal close window button on the top right of the window bar. They can also support a single checkbox and a single button interaction.
Available Buttons
The label on the single button changes according to the type of button called, they are the following:
Python Enum Button Label Return Value Bit Integer
RLPy.EMsgButton_NoButton "OK" 0 0-bit (2^0)
RLPy.EMsgButton_Ok "OK" 1024 10-bit (2^10)
RLPy.EMsgButton_Save "Save" 2048 11-bit (2^11)
RLPy.EMsgButton_SaveAll "Save All" 4096 12-bit (2^12)
RLPy.EMsgButton_Open "Open" 8196 13-bit (2^13)
RLPy.EMsgButton_Yes "Yes" 16384 14-bit (2^14)
RLPy.EMsgButton_YesToAll "Yes to All" 32768 15-bit (2^15)
RLPy.EMsgButton_No "No" 65536 16-bit (2^16)
RLPy.EMsgButton_NoToAll "No to All" 131072 17-bit (2^17)
RLPy.EMsgButton_Abort "Abort" 262144 18-bit (2^18)
RLPy.EMsgButton_Retry "Retry" 524288 19-bit (2^19)
RLPy.EMsgButton_Overlook "Ignore" 1048576 20-bit (2^20)
RLPy.EMsgButton_Close "Close" 2097152 21-bit (2^21)
RLPy.EMsgButton_Cancel "Cancel" 4194304 22-bit (2^22)
RLPy.EMsgButton_Discard "Discard" 8388608 23-bit (2^23)
RLPy.EMsgButton_Help "Help" 16777216 24-bit (2^24)
RLPy.EMsgButton_Apply "Apply" 33554432 25-bit (2^25)
RLPy.EMsgButton_Reset "Reset" 67108864 26-bit (2^26)
Non-Button Enumerations
The following are part of the EmsgButton enumerations but can't be used to create a dialog window.
Python Enum / User Action UI Representation Return Value Bit Integer
Dialog Exited Exit Button 2097152 21-bit (2^21)
RLPY.EMsgButton_RestoreDefaults None 134217728 27-bit (2^27)
Checkbox Activation
RLPy.EMsgButton_OkDontAskAgain
Check Box 268435456 28-bit (2^28)
Necessary Modules
The only required module for this lesson is the standard Reallusion Python API library.
import RLPy
Simple Message Box
The most simple message boxes just provide additional information to the user.
RLPy.RUi.ShowMessageBox(
    "Message 1/3",
    "Message boxes can block operations.",
    RLPy.EMsgButton_Ok)
Message Box with Checkbox
In addition, message boxes can support check-boxes for more complex interactions.
button_status = RLPy.RUi.ShowMessageBox(
    "Message 2/3",
    "We can demonstrate this with a check-box...",
    RLPy.EMsgButton_Close,
    True,
    "Try me!"
Action Blocking Message Boxes
Message boxes are asynchronous; they block the next action until the user removes it by clicking on the button or exiting the window.
    "Message 3/3",
    {RLPy.EMsgButton_Ok: "<b>False:</b> Checkbox was <b><i>NOT</i></b> activated.",
     RLPy.EMsgButton_OkDontAskAgain: "<b>True</b> Checkbox was activated!",
     RLPy.EMsgButton_Close: "<b>Canceled:</b> The message box was closed prematurely.",
     }[button_status],
    RLPy.EMsgButton_Ok
Adding More Buttons
You add more buttons by adding more enumerations separated by "|".
    "Ok and Cancel",
    "You can add more buttons.",
    RLPy.EMsgButton_Ok | RLPy.EMsgButton_Cancel
APIs Used
You can research the following references for the APIs deployed in this code.
