IC Python API:RLPy RlAudioObject
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/23/2020
Description
This class provides functionalities for audio objects in the scene to read and save sound files. Currently, only PCM format wav files are supported with the following channel, frequency, and bit rate configurations:
mono 16 bits stereo 16 bits
8 KHz
11 KHz
22 KHz
44 KHz
48 KHz
See Also: RAudio, RAudioRecorder
Member Functions
HasData ( self )
Check whether or not this audio object contains sound data.
Returns
True if this audio object contains sound data, else False - boolean
1 wav_path = "C:\\sample.wav"
2 self.audio_object = RLPy.RAudio.CreateAudioObject()
3 self.audio_object.Load(wav_path)
4 print(self.audio_object.HasData())  # True
Load ( self, strPath )
Load a sound file onto this audio object.
See Also RLPy.RIAudioObject.Save()
Parameters
strPath [IN] Audio file location - string
Return
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
Save ( self, strPath )
Save the sound data on this audio object to a wav file.
See Also RLPy.RIAudioObject.Load()
Parameters
strPath [IN] Location for saving the sound file - string
Return
1 wav_path = "E:\\sample.wav"
4 self.audio_object.Save("E:\\sample2.wav")
